주요 콘텐츠로 건너뛰기
How to Fix a Carabiner
필요한 것
  1. How to Fix a Carabiner, How to Fix a Carabiner: 1 단계, 이미지 1/1
    • Position the carabiner so that the gate is pushed forward past the nose and the latch is hanging out.
  2. How to Fix a Carabiner: 2 단계, 이미지 1/1
    • Position the pliers between the rivet pin.
    • The rivet pin is a flat rectangle metal piece poking out of the hinges.
  3. How to Fix a Carabiner: 3 단계, 이미지 1/1
    • Gently but firmly squeeze the rivet pin behind the hinge.
  4. How to Fix a Carabiner: 4 단계, 이미지 1/2 How to Fix a Carabiner: 4 단계, 이미지 2/2
    • Push the gate back, so that it is behind the nose.
    • Be sure to push the gate slowly and carefully, to avoid unnecessary jerking around, which could potentially break the carabiner further.
  5. How to Fix a Carabiner: 5 단계, 이미지 1/1
    • Position the gate back to the original position behind the nose.
  6. How to Fix a Carabiner: 6 단계, 이미지 1/1
    • The gate should now snap back into position securely. If it does not, repeat the process.
    • Be sure that the rivet pin was not bent or broken in the act of guiding the gate back to its original position.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Jala Boodram
회원 가입일: 02/04/20
178 평판
안내서 1개 작성함
댓글 2개
Thank you for tutorial I was autism and bent it.
Vehicular manslaughter - 답글
Was gonna throw the old one away but this helped. Good as new now, thanks!
Maksim Krotov - 답글
댓글 쓰기
조회 통계:
24 시간 전: 25
7일 전: 166
30일 전: 625
전체 시간: 19,353
