주요 콘텐츠로 건너뛰기
How to Fix a Carpet Dent
필요한 것
  1. How to Fix a Carpet Dent, How to Fix a Carpet Dent: 1 단계, 이미지 1개 중 1개
    • First decide what carpet dent you would like to fix.
  2. How to Fix a Carpet Dent: 2 단계, 이미지 1개 중 1개
    • Rake the carpet with the fork to break up the fibers in the carpet.
  3. How to Fix a Carpet Dent: 3 단계, 이미지 1개 중 1개
    • Submerge your white towel into the bowl of cold water.
  4. How to Fix a Carpet Dent: 4 단계, 이미지 1개 중 1개
    • Place the damp towel over the carpet dent and push down.
  5. How to Fix a Carpet Dent: 5 단계, 이미지 1개 중 1개
    • Put a steamer or clothes iron on top of the white towel so the heat from the steam can lift the carpet fibers.
  6. How to Fix a Carpet Dent: 6 단계, 이미지 1개 중 1개
    • Lift up your towel and see your brand new carpet!
    • The carpet may take an hour or two to fully dry, so be careful not to step on the wet area right away!
결론
In conclusion, this is an incredibly easy process which takes very little time and effort. Very helpful if you have just rearranged a room and do not want noticeable carpet dents.
작성자
1다른 기여자 명과 함께
Abigail Gaines
회원 가입일: 02/17/21
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 630
