소개
If you have a wooden chair with the armrest broken or loose, follow these simple steps to fix it. The steps are easy to follow and you are not going to need many tools to fix it. The tools that you can use to fix the armrest are easy to find in any hardware stores, or you might even have them in your house.
The processes will take 5 to 20 minutes to complete, but if you are not used to fixing things at home it may take longer than that. There are no requirements to execute these steps. Anybody can do the this fix.
필요한 것
Remove the armrest from the chair using a hex wrench screwdriver and a drill to remove the screws.
These are moderate step to fix your chair armrest.
다른 한 분이 해당 안내서를 완성하였습니다.
