주요 콘텐츠로 건너뛰기
How to Fix a Chair Armrest
필요한 것
  1. How to Fix a Chair Armrest, How to Fix a Chair Armrest: 1 단계, 이미지 3개 중 1개 How to Fix a Chair Armrest, How to Fix a Chair Armrest: 1 단계, 이미지 3개 중 2개 How to Fix a Chair Armrest, How to Fix a Chair Armrest: 1 단계, 이미지 3개 중 3개
    • Remove the armrest from the chair using a hex wrench screwdriver and a drill to remove the screws.
    • You can also use a screwdriver instead of a drill.
  2. How to Fix a Chair Armrest: 2 단계, 이미지 2개 중 1개 How to Fix a Chair Armrest: 2 단계, 이미지 2개 중 2개
    • This is the chair that we will fix, and the armrest that was broken.
  3. How to Fix a Chair Armrest: 3 단계, 이미지 2개 중 1개 How to Fix a Chair Armrest: 3 단계, 이미지 2개 중 2개
    • Sand just the inside tip of the armrest as shown.
  4. How to Fix a Chair Armrest: 4 단계, 이미지 2개 중 1개 How to Fix a Chair Armrest: 4 단계, 이미지 2개 중 2개
    • Apply a little bit of glue on the part that you sanded.
    • It is fine if you do not want to use glue.
  5. How to Fix a Chair Armrest: 5 단계, 이미지 2개 중 1개 How to Fix a Chair Armrest: 5 단계, 이미지 2개 중 2개
    • Put the screw washer on the screw.
  6. How to Fix a Chair Armrest: 6 단계, 이미지 3개 중 1개 How to Fix a Chair Armrest: 6 단계, 이미지 3개 중 2개 How to Fix a Chair Armrest: 6 단계, 이미지 3개 중 3개
    • Insert the screw inside the hole on the inside of the chair body.
    • Have another person attach the armrest and then screw it with your hand.
  7. How to Fix a Chair Armrest: 7 단계, 이미지 2개 중 1개 How to Fix a Chair Armrest: 7 단계, 이미지 2개 중 2개
    • Insert the screw into the end of the armrest, attaching it to the edge of the back of the chair using a drill.
    • You may also use a screwdriver instead of a drill.
  8. How to Fix a Chair Armrest: 8 단계, 이미지 3개 중 1개 How to Fix a Chair Armrest: 8 단계, 이미지 3개 중 2개 How to Fix a Chair Armrest: 8 단계, 이미지 3개 중 3개
    • Tighten up the screw with a hex wrench screwdriver.
  9. How to Fix a Chair Armrest: 9 단계, 이미지 2개 중 1개 How to Fix a Chair Armrest: 9 단계, 이미지 2개 중 2개
    • All done! Now your armrest should feel securely attached to the chair.
결론
These are moderate step to fix your chair armrest.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Deviny
회원 가입일: 03/23/21
196 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 33
전체 시간: 3,251
