주요 콘텐츠로 건너뛰기
How to Fix a Correcting Tape
필요한 것
  1. How to Fix a Correcting Tape, How to Fix a Correcting Tape: 1 단계, 이미지 2개 중 1개 How to Fix a Correcting Tape, How to Fix a Correcting Tape: 1 단계, 이미지 2개 중 2개
    • From the button, open the case of the correcting tape.
  2. How to Fix a Correcting Tape: 2 단계, 이미지 2개 중 1개 How to Fix a Correcting Tape: 2 단계, 이미지 2개 중 2개
    • Cut from the middle of the extra correcting tape and remove those used parts.
    • Cut off those used parts from the place near the small gear.
  3. How to Fix a Correcting Tape: 3 단계, 이미지 1개 중 1개
    • Cut a small piece of the scotch tape.
  4. How to Fix a Correcting Tape: 4 단계, 이미지 1개 중 1개
    • Connect the remaining correction tape to the small gear by using a small piece of scotch tape.
  5. How to Fix a Correcting Tape: 5 단계, 이미지 1개 중 1개
    • After the connection is made, wrap the used tape tightly around the gear.
    • Put all the parts back in place.
  6. How to Fix a Correcting Tape: 6 단계, 이미지 1개 중 1개
    • Close the case of the correcting tape and snap back to place.
  7. How to Fix a Correcting Tape: 7 단계, 이미지 1개 중 1개
    • You're done!
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Yi Luo
회원 가입일: 10/26/18
220 평판
안내서 1개를 작성함
UC Davis, Team S2-G5, Bender Fall 2018 UC Davis, Team S2-G5, Bender Fall 2018 회원
UCD-BENDER-F18S2G5
2 회원들
안내서 1개 작성
3가이드 댓글
It probably cost me more time to put it together (first time) than it would to buy a new one. Doesn’t matter, fixed a problem! A sense of accomplishment and pride. %#*@, I love it so much.
Thanks for the guide.
The Swanson Disciple - 답글
This stuff is absolute junk! Wish I could find it packaged the old way, like Avery correction tape used to be, in little cardboard boxes. Hate all that plastic and these things always break for me!
Laker Girl - 답글
Well thank you for helping us and that was quite a shot thank you and god bless you and be safe during the virus!
Peata Faalaa - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 32
지난 30일: 137
전체 시간: 36,095
