주요 콘텐츠로 건너뛰기
How to Fix a Corroded Outdoor Water Spigot
필요한 것
  1. How to Fix a Corroded Outdoor Water Spigot, How to Fix a Corroded Outdoor Water Spigot: 1 단계, 이미지 1개 중 1개
    • Rinse the outside ring of the spigot off with water.
  2. How to Fix a Corroded Outdoor Water Spigot: 2 단계, 이미지 1개 중 1개
    • Once wet, apply 1 tbsp. of Bar Keepers Friend soft cleanser to the area(s) that has any built up residue.
  3. How to Fix a Corroded Outdoor Water Spigot: 3 단계, 이미지 1개 중 1개
    • Let the solution sit for 5-10 minutes.
  4. How to Fix a Corroded Outdoor Water Spigot: 4 단계, 이미지 1개 중 1개
    • Brush the cleanser that is on the spigot with a wire metal brush until you notice that the residue is gone.
  5. How to Fix a Corroded Outdoor Water Spigot: 5 단계, 이미지 1개 중 1개
    • Rinse the spigot off completely with water.
  6. How to Fix a Corroded Outdoor Water Spigot: 6 단계, 이미지 1개 중 1개
    • Using plumbers tape, wrap around the spigot once ensuring that is it fully covered.
  7. How to Fix a Corroded Outdoor Water Spigot: 7 단계, 이미지 1개 중 1개
    • Apply the connection for your garden hose securely to the spigot.
  8. How to Fix a Corroded Outdoor Water Spigot: 8 단계, 이미지 1개 중 1개
    • Turn on water to ensure there are no leaks/water sprays.
결론
작성자
1다른 기여자 명과 함께
Morgan Fluegel
회원 가입일: 03/23/21
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 57
전체 시간: 10,642
