주요 콘텐츠로 건너뛰기
How to Fix a Crack in a Hollow Wood Door
필요한 것
  1. How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: 1 단계, 이미지 1/2 How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: 1 단계, 이미지 2/2
    • Clean and dust the affected area with a paper towel, rag, or brush.
  2. How to Fix a Crack in a Hollow Wood Door: 2 단계, 이미지 1/1
    • Sand the affected area with a 60/80 grit sanding sponge.
    • Any type of sand paper or sanding sponge will work on wood surfaces.
    • It is recommended to place newspaper under the door to keep the sand/dust contained.
  3. How to Fix a Crack in a Hollow Wood Door: 3 단계, 이미지 1/1
    • Remove any sand/dust with a paper towel.
    • It is recommend to use gloves to prevent any minor splinters.
    • It is also recommended to use a face mask to prevent inhaling any dust/sand.
  4. How to Fix a Crack in a Hollow Wood Door: 4 단계, 이미지 1/1
    • Use putty knife to apply body filler until an even layer is formed.
    • Start with a small amount and then add more if needed.
    • A smaller putty knife allows for easier application in creases and folds.
  5. How to Fix a Crack in a Hollow Wood Door: 5 단계, 이미지 1/1
    • Remove any excess body filler with putty knife
    • Its okay if the surface is uneven, you will use sandpaper to smooth the surface in a later step.
  6. How to Fix a Crack in a Hollow Wood Door: 6 단계, 이미지 1/1
    • Allow to dry (or use a blow dryer for lesser wait time).
    • More expensive brands of body filler will dry faster.
  7. How to Fix a Crack in a Hollow Wood Door: 7 단계, 이미지 1/2 How to Fix a Crack in a Hollow Wood Door: 7 단계, 이미지 2/2
    • Gently sand the surface.
    • Gloves and a face mask are highly recommended but not required for this step.
    • Newspaper is also recommended to contain any sand/dust.
    • Reapply body filler, allow to dry, and re-sand if surface remains uneven.
  8. How to Fix a Crack in a Hollow Wood Door: 8 단계, 이미지 1/1
    • Use a similar toned paint to paint the area if any discoloration exists.
    • Wood paint is ideal for wood doors.
  9. How to Fix a Crack in a Hollow Wood Door: 9 단계, 이미지 1/1
    • Allow to dry.
    • Your door should now look neutral and clean.
    • A blow dryer is recommended for faster drying.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Lea Thomas
회원 가입일: 01/20/19
250 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 회원
USFSM-STEWART-S19S1G1
18 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 57
7일 전: 500
30일 전: 2,175
전체 시간: 132,330
