이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
Sand the affected area with a 60/80 grit sanding sponge.
Any type of sand paper or sanding sponge will work on wood surfaces.
It is recommended to place newspaper under the door to keep the sand/dust contained.
Remove any sand/dust with a paper towel.
It is recommend to use gloves to prevent any minor splinters.
It is also recommended to use a face mask to prevent inhaling any dust/sand.
Use putty knife to apply body filler until an even layer is formed.
Start with a small amount and then add more if needed.
A smaller putty knife allows for easier application in creases and folds.
Remove any excess body filler with putty knife
Its okay if the surface is uneven, you will use sandpaper to smooth the surface in a later step.
Gently sand the surface.
Gloves and a face mask are highly recommended but not required for this step.
Newspaper is also recommended to contain any sand/dust.
Reapply body filler, allow to dry, and re-sand if surface remains uneven.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
미리보기
