주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Fix a Cracked Fingernail
필요한 것
  1. How to Fix a Cracked Fingernail, How to Fix a Cracked Fingernail: 1 단계, 이미지 2개 중 1개 How to Fix a Cracked Fingernail, How to Fix a Cracked Fingernail: 1 단계, 이미지 2개 중 2개
    • Examine the crack and clean off as much nail polish and grime as possible.
    댓글 쓰기
  2. How to Fix a Cracked Fingernail: 2 단계, 이미지 2개 중 1개 How to Fix a Cracked Fingernail: 2 단계, 이미지 2개 중 2개
    • Cut out a small rectangle from a teabag.
    • It should be big enough to cover the crack.
    댓글 쓰기
  3. How to Fix a Cracked Fingernail: 3 단계, 이미지 1개 중 1개
    • Add a drop of glue to the crack.
    댓글 쓰기
  4. How to Fix a Cracked Fingernail: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Place the cut out teabag on top of the glue to cover the whole crack.
    • Gently press down on the rectangle with tweezers to make it flat on the nail.
    댓글 쓰기
  5. How to Fix a Cracked Fingernail: 5 단계, 이미지 2개 중 1개 How to Fix a Cracked Fingernail: 5 단계, 이미지 2개 중 2개
    • Cut off the excess teabag after the glue is dry.
    • Apply more glue (after trimming) to cover the teabag, making sure it's all coated and flat on the nail surface.
    댓글 쓰기
  6. How to Fix a Cracked Fingernail: 6 단계, 이미지 2개 중 1개 How to Fix a Cracked Fingernail: 6 단계, 이미지 2개 중 2개
    • After the glue is dry, use a nail filer to shape the nail and a nail buffer to smooth out the top surface of the nail.
    댓글 쓰기
  7. How to Fix a Cracked Fingernail: 7 단계, 이미지 3개 중 1개 How to Fix a Cracked Fingernail: 7 단계, 이미지 3개 중 2개 How to Fix a Cracked Fingernail: 7 단계, 이미지 3개 중 3개
    • After you finish shaping and buffing the nail, wash your hands in lukewarm water.
    • The nail should feel smooth and the crack should be sealed.
    • For extra reinforcement, you can paint your nails or add only a topcoat (clear) nail polish. Painting your nails is completely optional.
    댓글 쓰기
결론
This fix can help you keep your nail from getting caught on things if the crack is too low to cut off the excess. Try to avoid soaking the nail in water for too long since it can make the nail softer and reduce the effectiveness of the adhesion on the nail. Please seek medical attention if the crack is serious and is causing a lot of pain and/or discoloration.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Tammy Chung
회원 가입일: 07/08/21
154 평판
안내서 1개를 작성함
4가이드 댓글
Thanks for sharing. I've broken my nail just yesterday:(
goddyhevil - 답글 공유
Thank you for the article. The information might be useful next time I break my nail.
sentinmorty - 답글 공유
Thanks for the detailed guide! I didn’t know it was that easy to do it alone. Every time my ail breaks, I just ask my friend to fix it somehow. She studies at nail master's college https://www.nwcollege.edu/programs/nail-... and knows how to do it. She has already bought some equipment and materials for a manicure; I’m usually her model. To tell the truce, she must be very talented because the nails done by her are better than those I pay a lot for. However, it’s hard to get to her place (she lives in another town), which is the only disadvantage of our friendship. I like having a friend who is a nail master because it saves me a lot.
jenniferelder - 답글 공유
this is awsome i have very long nails and i really dont want to trim them off so this gave alot of advise
Bibi Sara - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 68
전체 시간: 2,203
