주요 콘텐츠로 건너뛰기
How to Fix a Crooked Cabinet
필요한 것
  1. How to Fix a Crooked Cabinet, Examine the Issue: 1 단계, 이미지 3개 중 1개 How to Fix a Crooked Cabinet, Examine the Issue: 1 단계, 이미지 3개 중 2개 How to Fix a Crooked Cabinet, Examine the Issue: 1 단계, 이미지 3개 중 3개
    • Examine which door needs to be adjusted and to what extent. In this example, we start the adjustment with the lower screws of the cabinet door.
  2. How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: 2 단계, 이미지 3개 중 1개 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: 2 단계, 이미지 3개 중 2개 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: 2 단계, 이미지 3개 중 3개
    • Hold onto the cabinet as you unscrew the two bottom screws to reposition it.
    • Select the appropriate screwdriver bit.
    • Tighten the screws to adjust appropriately.
  3. How to Fix a Crooked Cabinet, Repeat with the Top Screws: 3 단계, 이미지 3개 중 1개 How to Fix a Crooked Cabinet, Repeat with the Top Screws: 3 단계, 이미지 3개 중 2개 How to Fix a Crooked Cabinet, Repeat with the Top Screws: 3 단계, 이미지 3개 중 3개
    • Repeat Step 2 with the screws at the top.
  4. How to Fix a Crooked Cabinet, Adjust to Gap: 4 단계, 이미지 1개 중 1개
    • The gap should be even from top to bottom. Ensure that it is and hold the cabinet in place to adjust if it is not.
  5. How to Fix a Crooked Cabinet, Feel Accomplished: 5 단계, 이미지 2개 중 1개 How to Fix a Crooked Cabinet, Feel Accomplished: 5 단계, 이미지 2개 중 2개
    • You've done it! As long as the gap is even, your results should be just like this.
    • Great job!
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Elmore Smith
회원 가입일: 11/20/22
196 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 33
지난 30일: 155
전체 시간: 3,409
