주요 콘텐츠로 건너뛰기
How to Fix a Damaged VHS Tape
필요한 것
  1. How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: 1 단계, 이미지 3개 중 1개 How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: 1 단계, 이미지 3개 중 2개 How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: 1 단계, 이미지 3개 중 3개
    • Remove the screws at the bottom of the VHS case using a Phillips #0 screwdriver.
  2. How to Fix a Damaged VHS Tape: 2 단계, 이미지 2개 중 1개 How to Fix a Damaged VHS Tape: 2 단계, 이미지 2개 중 2개
    • Lift open the cover of the VHS.
  3. How to Fix a Damaged VHS Tape: 3 단계, 이미지 2개 중 1개 How to Fix a Damaged VHS Tape: 3 단계, 이미지 2개 중 2개
    • Remove the top cover of the VHS case.
  4. How to Fix a Damaged VHS Tape: 4 단계, 이미지 3개 중 1개 How to Fix a Damaged VHS Tape: 4 단계, 이미지 3개 중 2개 How to Fix a Damaged VHS Tape: 4 단계, 이미지 3개 중 3개
    • Replace any rollers that accidently fall out of the VHS case.
  5. How to Fix a Damaged VHS Tape: 5 단계, 이미지 3개 중 1개 How to Fix a Damaged VHS Tape: 5 단계, 이미지 3개 중 2개 How to Fix a Damaged VHS Tape: 5 단계, 이미지 3개 중 3개
    • Unroll the video tape from each side of the VHS, running it through the rollers the correct way. Do this until you reach the damaged parts of the tape.
  6. How to Fix a Damaged VHS Tape: 6 단계, 이미지 3개 중 1개 How to Fix a Damaged VHS Tape: 6 단계, 이미지 3개 중 2개 How to Fix a Damaged VHS Tape: 6 단계, 이미지 3개 중 3개
    • Cut out the wrinkled and damaged parts of the VHS tape using scissors.
  7. How to Fix a Damaged VHS Tape: 7 단계, 이미지 1개 중 1개
    • Hold the undamaged parts of the tape over each other as evenly as possible.
  8. How to Fix a Damaged VHS Tape: 8 단계, 이미지 2개 중 1개 How to Fix a Damaged VHS Tape: 8 단계, 이미지 2개 중 2개
    • Cut the overlapping portion of the tape at an angle.
  9. How to Fix a Damaged VHS Tape: 9 단계, 이미지 2개 중 1개 How to Fix a Damaged VHS Tape: 9 단계, 이미지 2개 중 2개
    • Apply scotch tape to the dull side of the two matching halves of the VHS tape.
    • Potential for device damage: Do not wrap the scotch tape around the other side of the VHS tape.
  10. How to Fix a Damaged VHS Tape: 10 단계, 이미지 3개 중 1개 How to Fix a Damaged VHS Tape: 10 단계, 이미지 3개 중 2개 How to Fix a Damaged VHS Tape: 10 단계, 이미지 3개 중 3개
    • Cut excess scotch tape to match the size of the VHS tape as precisely as possible.
  11. How to Fix a Damaged VHS Tape: 11 단계, 이미지 3개 중 1개 How to Fix a Damaged VHS Tape: 11 단계, 이미지 3개 중 2개 How to Fix a Damaged VHS Tape: 11 단계, 이미지 3개 중 3개
    • Wind the loose VHS tape back into the case.
  12. How to Fix a Damaged VHS Tape: 12 단계, 이미지 3개 중 1개 How to Fix a Damaged VHS Tape: 12 단계, 이미지 3개 중 2개 How to Fix a Damaged VHS Tape: 12 단계, 이미지 3개 중 3개
    • Replace the cover back on top of the VHS case.
  13. How to Fix a Damaged VHS Tape: 13 단계, 이미지 3개 중 1개 How to Fix a Damaged VHS Tape: 13 단계, 이미지 3개 중 2개 How to Fix a Damaged VHS Tape: 13 단계, 이미지 3개 중 3개
    • Reinsert the screws through the bottom of the VHS tape.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nicholas Monroe
회원 가입일: 03/23/21
265 평판
안내서 1개를 작성함
3가이드 댓글
Na het monteren van de tape, en voor het sluiten van de cassette hield ik nog een klein zwart onderdeeltje over en kan het niet meer herplaatsen, deel omdat de behuizing nagenoeg zwart is, en ook omdat ik niets wil forceren. Zou een tip om de plaats van dit onderdeel te vinden enorm op prijs stellen.
Jan - 답글
Inmiddels van iemand een VHS band geleend, opengemaakt en vastgesteld waar het blokje past, bij de afbeelding 4 en 5 is dat helaas slecht te zien, maar het blokje past in een kleine ruimte tussen de twee spoelen. Het zou mooi zijn, als je plaatjes kon toevoegen, maar goed probleem opgelost, en nu opnieuw met de videograbber aan de slag, wat leveren de Kabelshop en NEDIS een slecht service, door steeds verwijzen dat het aan de kabel ligt, de videospeler, of de aansluiting met de Windows PC, feitelijk stijllloos.
Jan - 답글
domz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 45
지난 30일: 195
전체 시간: 12,100
