주요 콘텐츠로 건너뛰기
How to Fix a Delta 5-Function Showerhead Model 75554
필요한 것
  1. How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: 1 단계, 이미지 3개 중 1개 How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: 1 단계, 이미지 3개 중 2개 How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: 1 단계, 이미지 3개 중 3개
    • Unscrew the head of the shower from the pipe with a pipe wrench.
    • While using the pipe wrench, make sure not to clamp it too tight because it will crack the plastic.
  2. How to Fix a Delta 5-Function Showerhead Model 75554: 2 단계, 이미지 2개 중 1개 How to Fix a Delta 5-Function Showerhead Model 75554: 2 단계, 이미지 2개 중 2개
    • Fill a large bowl with equal parts hot water and white distilled vinegar to get rid of hard water build up.
  3. How to Fix a Delta 5-Function Showerhead Model 75554: 3 단계, 이미지 2개 중 1개 How to Fix a Delta 5-Function Showerhead Model 75554: 3 단계, 이미지 2개 중 2개
    • With the tip of a pocketknife, pick out the rubber, black washer in the attachment.
    • Using your fingertips press a new 1" black rubber washer into the head attachment. The new washer will allow water to flow correctly with more pressure.
    • Pocketknives can be very very sharp!
  4. How to Fix a Delta 5-Function Showerhead Model 75554: 4 단계, 이미지 2개 중 1개 How to Fix a Delta 5-Function Showerhead Model 75554: 4 단계, 이미지 2개 중 2개
    • Wipe down with shower pipe with a hot water and vinegar soaked scrub brush.
  5. How to Fix a Delta 5-Function Showerhead Model 75554: 5 단계, 이미지 2개 중 1개 How to Fix a Delta 5-Function Showerhead Model 75554: 5 단계, 이미지 2개 중 2개
    • Wrap Teflon tape around the legs of the spout about 3 times to ensure that it will screw on tight when the head is put back on.
    • Now is the time to take the shower head out of the vinegar water.
  6. How to Fix a Delta 5-Function Showerhead Model 75554: 6 단계, 이미지 3개 중 1개 How to Fix a Delta 5-Function Showerhead Model 75554: 6 단계, 이미지 3개 중 2개 How to Fix a Delta 5-Function Showerhead Model 75554: 6 단계, 이미지 3개 중 3개
    • Twist the shower head back onto the pipe and tighten it with the pipe wrench.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Faith Henson
회원 가입일: 04/08/19
160 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 1,516
