이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This repair guide is a step-by-step of instructions to ensure you are using the correct materials and tools to fix your Delta 5-Function Showerhead Model 75554. This showerhead has a major leak in it, which I have found that it is where is screws onto the shower pipe itself. The reasoning behind this guide is that it gets very slippery when I walk into my shower because of how bad, and often the head is leaking.
필요한 것
Unscrew the head of the shower from the pipe with a pipe wrench.
다른 한 분이 해당 안내서를 완성하였습니다.
