이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Fill a large bowl with equal parts hot water and white distilled vinegar to get rid of hard water build up.
With the tip of a pocketknife, pick out the rubber, black washer in the attachment.
Using your fingertips press a new 1" black rubber washer into the head attachment. The new washer will allow water to flow correctly with more pressure.
Wipe down with shower pipe with a hot water and vinegar soaked scrub brush.
Wrap Teflon tape around the legs of the spout about 3 times to ensure that it will screw on tight when the head is put back on.
Twist the shower head back onto the pipe and tighten it with the pipe wrench.
다른 한 분이 해당 안내서를 완성하였습니다.
