주요 콘텐츠로 건너뛰기
How to Fix a Dent in a Hardside Suitcase
필요한 것
  1. How to Fix a Dent in a Hardside Suitcase, How to Fix a Dent in a Hardside Suitcase: 1 단계, 이미지 1개 중 1개
    • Before you begin, determine which tool is best to use for tapping out the dent, as this depends on the size of the dent. For this guide, the handle of a screwdriver was used, but a soft mallet would work well too.
  2. How to Fix a Dent in a Hardside Suitcase: 2 단계, 이미지 1개 중 1개
    • Use the hair dryer on the dented area for a duration of 3 minutes.
    • Move the hair dryer around the dented area to avoid heat damage to your suitcase. Wear heat-resistant gloves and check the area periodically to ensure it is not overheating.
  3. How to Fix a Dent in a Hardside Suitcase: 3 단계, 이미지 2개 중 1개 How to Fix a Dent in a Hardside Suitcase: 3 단계, 이미지 2개 중 2개
    • Open the suitcase and use a screwdriver handle or soft mallet to tap out the dent about 3-5 times.
    • The screwdriver is being used to shape the dent back to its original shape towards the outside of the luggage.
  4. How to Fix a Dent in a Hardside Suitcase: 4 단계, 이미지 1개 중 1개
    • Use a hair dryer to apply heat to the dented area for 1-3 minutes, moving the heat over the area in a circular motion.
    • This will soften the suitcase material so it's easier to tap out the dent.
  5. How to Fix a Dent in a Hardside Suitcase: 5 단계, 이미지 1개 중 1개
    • Use a screwdriver handle or soft mallet to tap the dent back to the original shape or as close to it as possible. Hit the dent using your tool about 4-6 times.
  6. How to Fix a Dent in a Hardside Suitcase: 6 단계, 이미지 1개 중 1개
    • The process is complete and the suitcase is back to its normal shape and can be used!
결론
작성자
3다른 기여자 명과 함께
Samirah
회원 가입일: 02/02/24
138 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 91
전체 시간: 2,402
