주요 콘텐츠로 건너뛰기
How to Fix a Dirty Censor in a Corsair Harpoon RGB
필요한 것
  1. How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: 1 단계, 이미지 1/2 How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: 1 단계, 이미지 2/2
    • Start by flipping the mouse over to view the flat side of the mouse.
    • Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
  2. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 2 단계, 이미지 1/3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 2 단계, 이미지 2/3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
    • Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
    • The mouse will be pulled into two pieces: the top (rounded part) and bottom (flat part).
  3. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 3 단계, 이미지 1/1
    • After the mouse has been pulled apart, the flex cable will be visible. This must be removed before continuing.
    • To remove the flex cable, gently pull the cable clip until it becomes unlatched.
  4. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 4 단계, 이미지 1/2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 4 단계, 이미지 2/2
    • Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
  5. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 5 단계, 이미지 1/2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 5 단계, 이미지 2/2
    • Once the motherboard is removed, the optical sensor will be fully exposed. This is the piece that is causing the lag in the mouse.
    • The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
결론
To disassemble, clean, and reassemble your mouse, follow these guidelines.
다른 3명이 해당 안내서를 완성하였습니다.
Kady Volmering
회원 가입일: 03/16/21
200 평판
안내서 1개 작성함
댓글 2개
Muy buena guia. Me fue muy util. Gracias y saludos.
Bolzano - 답글
why did you opened it if you just cleaned eye with alcohol
antoncoinz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 41
30일 전: 172
전체 시간: 6,149
