주요 콘텐츠로 건너뛰기
How to Fix a Dry Printer Cartridge
필요한 것
  1. How to Fix a Dry Printer Cartridge, Removing the Cartridge: 1 단계, 이미지 1/3 How to Fix a Dry Printer Cartridge, Removing the Cartridge: 1 단계, 이미지 2/3 How to Fix a Dry Printer Cartridge, Removing the Cartridge: 1 단계, 이미지 3/3
    • Open the top case of your printer.
    • Carefully remove the dried cartridge by lifting the flap in the bottom right section of the printer.
  2. How to Fix a Dry Printer Cartridge, Applying Hand Sanitizer: 2 단계, 이미지 1/2 How to Fix a Dry Printer Cartridge, Applying Hand Sanitizer: 2 단계, 이미지 2/2
    • Place the cartridge on a clean surface and apply a few drops of alcohol-based hand sanitizer to the ink nozzle.
    • It's best to use an unscented hand sanitizer, as some scents or colors in the hand sanitizer may affect your ink cartridge's performance.
    • Gently rub your finger on the ink nozzle once or twice.
    • Let the sanitizer seep in for a few minutes.
    • While you wait, fill a bowl halfway with warm tap water.
  3. How to Fix a Dry Printer Cartridge, Wipe it out: 3 단계, 이미지 1/2 How to Fix a Dry Printer Cartridge, Wipe it out: 3 단계, 이미지 2/2
    • Wipe out the ink nozzle where you applied the sanitizer with a clean cloth or paper towel.
  4. How to Fix a Dry Printer Cartridge, Warm Water Bath: 4 단계, 이미지 1/3 How to Fix a Dry Printer Cartridge, Warm Water Bath: 4 단계, 이미지 2/3 How to Fix a Dry Printer Cartridge, Warm Water Bath: 4 단계, 이미지 3/3
    • Place the nozzle side of the cartridge into a bowl filled with warm water.
    • Do not completely submerge the cartridge inside the water, just half of it.
    • Wait for 5-10 mins or until you see ink leaking out into the water.
    • Once you see ink leaking out, remove the cartridge from the water carefully.
    • It may be a good idea to keep a bit of paper towel or a rag handy to catch any drips from the ink cart.
  5. How to Fix a Dry Printer Cartridge, Dry it Completely: 5 단계, 이미지 1/1
    • After removing it from the water, completely clean the cartridge with a soft cloth or a paper towel and dry it out.
    • DO NOT put a wet cartridge inside the printer, else it can damage it.
  6. How to Fix a Dry Printer Cartridge, Double Check: 6 단계, 이미지 1/1
    • To make sure the cartridge is fully working now, take a piece of paper and rub the ink nozzle over it.
    • When you see an ink line on the paper, that means you are good to go.
  7. How to Fix a Dry Printer Cartridge, Fixing it Back: 7 단계, 이미지 1/1
    • Once the body of the cartridge has completely dried, place it back into the slot in the printer.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Hariom Godhani
회원 가입일: 10/01/21
382 평판
안내서 1개 작성함
York University, Team F-13, Woodhouse Fall 2021 York University, Team F-13, Woodhouse Fall 2021 회원
YORK-WOODHOUSE-F21SFG13
2 회원들
안내서 6개 작성하였습니다
댓글 5개
Thank you. This worked for me.
Thomas Grace - 답글
This actually worked . Did just as you instructed , didn't see ink in the hot water but after a few minutes I dried the cartridges off and had ink on the paper towel . Worked great ,Thanks Hariom .
Tim - 답글
Tried this with HP 60 black and tri-colour cartridges, which were both brand new, sealed cartridges, but were probably sitting in the box since ~2008. It did manage to loosen the ink up enough that if I ran the nozzle along a damp coffee filter, it would leave a solid black line, or in the case of the colour cartridge, a line of 3 stripes: cyan, yellow, then magenta. Unfortunately, the moment I dry them off and pop them back in the printer, nothing happens. I did manage to get the faded mostly cyan top third of a test page once, but that was it. Repeated the process more thoroughly, and got a more consistent output of ink on the filter, but the result after that was nothing but blank sheets.
Not really sure what to do beyond this, because I could probably just pick up a new printer for the price of these cartridges. This would probably work well for newer cartridges that were printing fine, but then were just left idle for a few months too long between prints.
Jordan “gordo” Zanatta - 답글
At least you tried it and you know what to do if the cartridges aren't left for a lessor time.
DEAN -
댓글 쓰기
조회 통계:
24 시간 전: 54
7일 전: 297
30일 전: 1,495
전체 시간: 30,759
