주요 콘텐츠로 건너뛰기
How to Fix a Dry Printer Cartridge
필요한 것
  1. How to Fix a Dry Printer Cartridge, Removing the Cartridge: 1 단계, 이미지 3개 중 1개 How to Fix a Dry Printer Cartridge, Removing the Cartridge: 1 단계, 이미지 3개 중 2개 How to Fix a Dry Printer Cartridge, Removing the Cartridge: 1 단계, 이미지 3개 중 3개
    • Open the top case of your printer.
    • Carefully remove the dried cartridge by lifting the flap in the bottom right section of the printer.
  2. How to Fix a Dry Printer Cartridge, Applying Hand Sanitizer: 2 단계, 이미지 2개 중 1개 How to Fix a Dry Printer Cartridge, Applying Hand Sanitizer: 2 단계, 이미지 2개 중 2개
    • Place the cartridge on a clean surface and apply a few drops of alcohol-based hand sanitizer to the ink nozzle.
    • It's best to use an unscented hand sanitizer, as some scents or colors in the hand sanitizer may affect your ink cartridge's performance.
    • Gently rub your finger on the ink nozzle once or twice.
    • Let the sanitizer seep in for a few minutes.
    • While you wait, fill a bowl halfway with warm tap water.
  3. How to Fix a Dry Printer Cartridge, Wipe it out: 3 단계, 이미지 2개 중 1개 How to Fix a Dry Printer Cartridge, Wipe it out: 3 단계, 이미지 2개 중 2개
    • Wipe out the ink nozzle where you applied the sanitizer with a clean cloth or paper towel.
  4. How to Fix a Dry Printer Cartridge, Warm Water Bath: 4 단계, 이미지 3개 중 1개 How to Fix a Dry Printer Cartridge, Warm Water Bath: 4 단계, 이미지 3개 중 2개 How to Fix a Dry Printer Cartridge, Warm Water Bath: 4 단계, 이미지 3개 중 3개
    • Place the nozzle side of the cartridge into a bowl filled with warm water.
    • Do not completely submerge the cartridge inside the water, just half of it.
    • Wait for 5-10 mins or until you see ink leaking out into the water.
    • Once you see ink leaking out, remove the cartridge from the water carefully.
    • It may be a good idea to keep a bit of paper towel or a rag handy to catch any drips from the ink cart.
  5. How to Fix a Dry Printer Cartridge, Dry it Completely: 5 단계, 이미지 1개 중 1개
    • After removing it from the water, completely clean the cartridge with a soft cloth or a paper towel and dry it out.
    • DO NOT put a wet cartridge inside the printer, else it can damage it.
  6. How to Fix a Dry Printer Cartridge, Double Check: 6 단계, 이미지 1개 중 1개
    • To make sure the cartridge is fully working now, take a piece of paper and rub the ink nozzle over it.
    • When you see an ink line on the paper, that means you are good to go.
  7. How to Fix a Dry Printer Cartridge, Fixing it Back: 7 단계, 이미지 1개 중 1개
    • Once the body of the cartridge has completely dried, place it back into the slot in the printer.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Hariom Godhani
회원 가입일: 10/01/21
502 평판
안내서 1개를 작성함
8가이드 댓글
Thank you. This worked for me.
Thomas Grace - 답글
This actually worked . Did just as you instructed , didn't see ink in the hot water but after a few minutes I dried the cartridges off and had ink on the paper towel . Worked great ,Thanks Hariom .
Tim - 답글
Tried this with HP 60 black and tri-colour cartridges, which were both brand new, sealed cartridges, but were probably sitting in the box since ~2008. It did manage to loosen the ink up enough that if I ran the nozzle along a damp coffee filter, it would leave a solid black line, or in the case of the colour cartridge, a line of 3 stripes: cyan, yellow, then magenta. Unfortunately, the moment I dry them off and pop them back in the printer, nothing happens. I did manage to get the faded mostly cyan top third of a test page once, but that was it. Repeated the process more thoroughly, and got a more consistent output of ink on the filter, but the result after that was nothing but blank sheets.
Not really sure what to do beyond this, because I could probably just pick up a new printer for the price of these cartridges. This would probably work well for newer cartridges that were printing fine, but then were just left idle for a few months too long between prints.
Jordan “gordo” Zanatta - 답글
At least you tried it and you know what to do if the cartridges aren't left for a lessor time.
DEAN -
댓글 쓰기
조회 통계:
지난 24시간: 25
지난 7일: 157
지난 30일: 744
전체 시간: 57,421
