주요 콘텐츠로 건너뛰기
How to Fix a Faulty Button on a Mayflash F300
필요한 것
  1. How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: 1 단계, 이미지 2개 중 1개 How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: 1 단계, 이미지 2개 중 2개
    • Flip around the Mayflash F300, so that the metal panel is facing you.
    • It may be helpful to place the device on a box if you cannot hold it, as the joystick would otherwise be under pressure.
  2. How to Fix a Faulty Button on a Mayflash F300: 2 단계, 이미지 3개 중 1개 How to Fix a Faulty Button on a Mayflash F300: 2 단계, 이미지 3개 중 2개 How to Fix a Faulty Button on a Mayflash F300: 2 단계, 이미지 3개 중 3개
    • Unscrew the six 9 mm Phillips #00 screws that hold together the metal panel.
    • Gently pry the panel away once it is unscrewed.
  3. How to Fix a Faulty Button on a Mayflash F300: 3 단계, 이미지 2개 중 1개 How to Fix a Faulty Button on a Mayflash F300: 3 단계, 이미지 2개 중 2개
    • Unplug the two cables going into the button you wish to clean or replace.
    • These two cables can be quite stubborn to remove, so gently wiggling them as you pull will make it easier.
  4. How to Fix a Faulty Button on a Mayflash F300: 4 단계, 이미지 1개 중 1개
    • Squeeze the two tabs that are on either side of the button and push it out.
  5. How to Fix a Faulty Button on a Mayflash F300: 5 단계, 이미지 1개 중 1개
    • Grab your toothbrush and clean out all the dirt you may find inside and around the button.
    • Alternatively, if you wish to install an entirely new button, you can simply set aside the old one.
  6. How to Fix a Faulty Button on a Mayflash F300: 6 단계, 이미지 2개 중 1개 How to Fix a Faulty Button on a Mayflash F300: 6 단계, 이미지 2개 중 2개
    • With your button now clean and ready to go, place it in the empty slot and push it back down. Make sure it snaps in place.
  7. How to Fix a Faulty Button on a Mayflash F300: 7 단계, 이미지 1개 중 1개
    • Reconnect the two cables to the button.
  8. How to Fix a Faulty Button on a Mayflash F300: 8 단계, 이미지 1개 중 1개
    • Take the back panel of the arcade stick and screw it back in place.
결론
Hopefully these steps were clear and useful to you! Happy gaming!
작성자
1다른 기여자 명과 함께
Ali Fareed
회원 가입일: 01/09/24
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 27
전체 시간: 651
