주요 콘텐츠로 건너뛰기
How to Fix a Flexi Leash
필요한 것
동영상 개요
  1. How to Fix a Flexi Leash, How to Fix a Flexi Leash: 1 단계, 이미지 1/1
    • Place the object in a clear bright space.
  2. How to Fix a Flexi Leash: 2 단계, 이미지 1/3 How to Fix a Flexi Leash: 2 단계, 이미지 2/3 How to Fix a Flexi Leash: 2 단계, 이미지 3/3
    • Start by removing all the 0.5 cm screws off the leash with the Phillips #0 screwdriver.
  3. How to Fix a Flexi Leash: 3 단계, 이미지 1/3 How to Fix a Flexi Leash: 3 단계, 이미지 2/3 How to Fix a Flexi Leash: 3 단계, 이미지 3/3
    • Using a plastic opening tool, begin to separate the top and bottom of the leash.
    • Make sure to press lightly to prevent unwanted marks.
    • It is most likely that the brake button will fall out. Place small items to the side to prevent it from being lost or undetected.
  4. How to Fix a Flexi Leash: 4 단계, 이미지 1/2 How to Fix a Flexi Leash: 4 단계, 이미지 2/2
    • Carefully remove the brake mechanism. Inside should be a small spring.
    • Remove and replace the spring with a new one.
    • When placing the break mechanism back into its place, make sure the spring is positioned right in the middle.
  5. How to Fix a Flexi Leash: 5 단계, 이미지 1/3 How to Fix a Flexi Leash: 5 단계, 이미지 2/3 How to Fix a Flexi Leash: 5 단계, 이미지 3/3
    • When the spring is successfully placed, initiate the retraction to it's original position.
    • Make sure the top and the bottom are aligned properly.
    • Slowly press the top and the bottom of the leash until it returns to its initial position.
  6. How to Fix a Flexi Leash: 6 단계, 이미지 1/3 How to Fix a Flexi Leash: 6 단계, 이미지 2/3 How to Fix a Flexi Leash: 6 단계, 이미지 3/3
    • Finish by screwing the 0.5 cm screws in their original position.
결승점
Joanette M. Anton Cordero
회원 가입일: 10/06/21
133 평판
안내서 1개 작성함
댓글 한 개
Where do i buy the spring?
Andrew Storeck - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 99
전체 시간: 3,954
