주요 콘텐츠로 건너뛰기
How to Fix a Gas Stove With Uneven Firing
필요한 것
  1. How to Fix a Gas Stove With Uneven Firing, How to Fix a Gas Stove With Uneven Firing: 1 단계, 이미지 3개 중 1개 How to Fix a Gas Stove With Uneven Firing, How to Fix a Gas Stove With Uneven Firing: 1 단계, 이미지 3개 중 2개 How to Fix a Gas Stove With Uneven Firing, How to Fix a Gas Stove With Uneven Firing: 1 단계, 이미지 3개 중 3개
    • Remember to wear gloves.
    • Remove the burner cap from the stove.
    • Remove the burner head from the stove.
    • Place both components on a paper towel to prevent staining the surface.
  2. How to Fix a Gas Stove With Uneven Firing: 2 단계, 이미지 2개 중 1개 How to Fix a Gas Stove With Uneven Firing: 2 단계, 이미지 2개 중 2개
    • Use a safety pin or toothpick to clean oily residue from the gaps between the separators.
  3. How to Fix a Gas Stove With Uneven Firing: 3 단계, 이미지 2개 중 1개 How to Fix a Gas Stove With Uneven Firing: 3 단계, 이미지 2개 중 2개
    • Pour the flour, white vinegar, and baking soda into a bowl.
    • Make sure the bowl is not used for eating because the next steps may stain the bowl.
    • Wear a mask to avoid getting smoked by the odor from the chemical reaction.
  4. How to Fix a Gas Stove With Uneven Firing: 4 단계, 이미지 1개 중 1개
    • Pour hot water into the bowl and let the chemical reaction occur.
  5. How to Fix a Gas Stove With Uneven Firing: 5 단계, 이미지 2개 중 1개 How to Fix a Gas Stove With Uneven Firing: 5 단계, 이미지 2개 중 2개
    • Put the gas stove burner into the bowl.
    • Soak the gas stove burner for 5 minutes.
  6. How to Fix a Gas Stove With Uneven Firing: 6 단계, 이미지 1개 중 1개
    • Remove the gas stove burner from the bowl.
    • Dry the burner using a towel.
  7. How to Fix a Gas Stove With Uneven Firing: 7 단계, 이미지 2개 중 1개 How to Fix a Gas Stove With Uneven Firing: 7 단계, 이미지 2개 중 2개
    • Put the gas stove burner back on the stove.
결론
If the residue on the separator has not been removed, you can repeat the process. You can increase the concentration of the liquid, reduce the volume of hot water, or soak it for a longer time to achieve better decontamination results.
작성자
2다른 기여자 명과 함께
Jessie
회원 가입일: 11/05/24
145 평판
안내서 1개를 작성함
UC Davis, Team 2-9, Vidal-Chiesa Fall 2024 UC Davis, Team 2-9, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S2G9
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 73
전체 시간: 885
