소개
Have you ever opened a door too hard and it hit the wall causing a small hole in the wall? This is a problem that so many people have, especially with children in the home. Most modern homes have walls made of a material called drywall. A hole in drywall is very easy to patch. It requires no prior skill or experience. This fix requires inexpensive tools and materials that you may find at a local hardware store or you may even already have some of these items at home. This is a guide on how to patch a small hole in the wall for beginners. This guide will include a complete step by step guide along with all tools and materials that are needed to complete this task.
필요한 것
Use pliers (or tweezers if the hole is very small) to clean out hole by removing the drywall out of the hole.
다른 4명이 해당 안내서를 완성하였습니다.
