주요 콘텐츠로 건너뛰기
How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line
필요한 것
  1. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line, How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 1 단계, 이미지 1/1
    • Move the dial to a vertical position to close the fuel line.
    • This will prevent fluids from continuing to move freely throughout the lawnmower.
  2. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 2 단계, 이미지 1/3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 2 단계, 이미지 2/3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 2 단계, 이미지 3/3
    • Use the screwdriver to push the right tension pin to the right so the hose can be removed.
    • Remove the right hose by wiggling the screwdriver between the hose and the tube where it is attached.
    • Have the empty bottle ready to use as soon as the hose is detached from the fuel line.
  3. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 3 단계, 이미지 1/1
    • Place the hose into a bottle to catch the leaking fluid from the fuel tank.
    • More liquid will be released from the right hose than in any other part of the process.
  4. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 4 단계, 이미지 1/3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 4 단계, 이미지 2/3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 4 단계, 이미지 3/3
    • Move the tension pin to the left to allow the hose to be removed.
    • Remove the left hose and catch the fluids that leak out.
  5. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 5 단계, 이미지 1/2 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 5 단계, 이미지 2/2
    • Remove the 10 mm bolt holding the carburetor fuel cup in place.
    • Remove the carburetor fuel cup
    • Use the rag to clean the inside of the carburetor fuel cup after it has been removed.
    • Let any fluid released from removing the carburetor spill onto the rag.
  6. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 6 단계, 이미지 1/1
    • Tilt the lawnmower forward so any remaining fluids can make their way out.
  7. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 7 단계, 이미지 1/1
    • Place the detached hoses back to the fuel line.
    • Move the pins back to the end of the hose to hold them in place.
  8. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 8 단계, 이미지 1/1
    • Use the fuel can to refill the lawnmower now that the contaminated fuel has been removed.
  9. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: 9 단계, 이미지 1/1
    • Turn the dial to a horizontal position to reopen the fuel line.
결론
With the water out of the fuel line, the lawnmower should be ready for use.
다른 2명이 해당 안내서를 완성하였습니다.
Alonso Pantoja
회원 가입일: 01/24/22
223 평판
안내서 1개 작성함
CSU Los Angeles, Team 6-10, Briggs Spring 2022 CSU Los Angeles, Team 6-10, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S6G10
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 20
30일 전: 102
전체 시간: 1,813
