주요 콘텐츠로 건너뛰기
How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock
필요한 것
  1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 1 단계, 이미지 1/2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 1 단계, 이미지 2/2
    • Make sure the lock is in the unlock position when you start.
    • Use a Philips #1 screwdriver to remove the two 8 mm screws from the left and right sides of the lock.
  2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 2 단계, 이미지 1/3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 2 단계, 이미지 2/3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 2 단계, 이미지 3/3
    • Lift the faceplate from the lock.
    • Locate the battery pack stationed at the top of the lock and the programming button at the center of the lock.
  3. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 3 단계, 이미지 1/1
    • Pull the battery pack up and off to remove it from the lock housing.
  4. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 4 단계, 이미지 1/2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 4 단계, 이미지 2/2
    • Re-insert the battery pack while holding down the programming button.
    • Ensure the battery pack is fully inserted by pushing it down.
  5. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 5 단계, 이미지 1/3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 5 단계, 이미지 2/3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 5 단계, 이미지 3/3
    • Release the programming button after the indicator light turns red then green.
    • Repeat steps 3 through 5 if the light does not turn green.
  6. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 6 단계, 이미지 1/2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 6 단계, 이미지 2/2
    • Press the program button again to allow the Smartlock to re-calibrate and reprogram itself.
    • The lock will lock and unlock a few times to calibrate and will remain in the lock position when the calibration is complete.
  7. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 7 단계, 이미지 1/3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 7 단계, 이미지 2/3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: 7 단계, 이미지 3/3
    • To reassemble your lock, reseat the faceplate on the lock.
    • Twist the lock switch until it aligns with the bolt mechanism and the faceplate sits flush against the lock.
    • Use the Phillips #1 screwdriver to secure the two 8 mm screws back into place to conclude the fix.
결론
Your lock will not jam anymore!
다른 한 분이 해당 안내서를 완성하였습니다.
Manpreet Sahota
회원 가입일: 09/09/21
145 평판
안내서 1개 작성함
York University, Team 1-21, O'Regan Fall 2021 York University, Team 1-21, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S1G21
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 84
30일 전: 319
전체 시간: 14,431
