주요 콘텐츠로 건너뛰기
How to Fix a Leaky Gutter
필요한 것
  1. How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: 1 단계, 이미지 3개 중 1개 How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: 1 단계, 이미지 3개 중 2개 How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: 1 단계, 이미지 3개 중 3개
    • Clean the area around the leak with a wire bush or garden trowel and a bucket, taking out the leaves and debris placing what you remove in the bucket and flushing the gutters with water using a hose to make sure you have a clean area, as well as rinsing and drying the area thoroughly.
    • Since this requires a ladder, it is better to have another adult nearby just to stay safe!
  2. How to Fix a Leaky Gutter: 2 단계, 이미지 1개 중 1개
    • Apply plastic roofing cement to any holes present in the gutters by working it into the hole or crack with a putty knife or trowel.
  3. How to Fix a Leaky Gutter: 3 단계, 이미지 1개 중 1개
    • Smooth out the cement by using the putty knife or trowel so that can smooth out any rough edges.
  4. How to Fix a Leaky Gutter: 4 단계, 이미지 1개 중 1개
    • Remove any screws or connecting hardware at the joint of any leaking or worn portion of the downspout and then disassemble any leaking or worn portion of the downspout joint.
  5. How to Fix a Leaky Gutter: 5 단계, 이미지 1개 중 1개
    • Clean any caulks from around the downspout joints using a stiff wire brush.
  6. How to Fix a Leaky Gutter: 6 단계, 이미지 1개 중 1개
    • Apply the silicone caulk to the joint area to seal leaks and reassemble the gutter system.
결론
To reassemble the downsprout: screw back any screws or connecting hardware back into the downsprout.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Aya Mansour
회원 가입일: 02/16/21
214 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 79
전체 시간: 2,976
