주요 콘텐츠로 건너뛰기
How to Fix a Leaning Wooden Gate
필요한 것
  1. How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: 1 단계, 이미지 2개 중 1개 How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: 1 단계, 이미지 2개 중 2개
    • Begin by measuring the gap under the gate to determine the exact height needed for correction.
  2. How to Fix a Leaning Wooden Gate: 2 단계, 이미지 1개 중 1개
    • Choose any object that is the same size as the measured gap.
    • Place the selected object under the gate to ensure the gate is level and straight.
  3. How to Fix a Leaning Wooden Gate: 3 단계, 이미지 3개 중 1개 How to Fix a Leaning Wooden Gate: 3 단계, 이미지 3개 중 2개 How to Fix a Leaning Wooden Gate: 3 단계, 이미지 3개 중 3개
    • Place the wheel on the side where the door is leaning down.
    • Mark the hole location for drilling.
    • Use masking tape only if the door is the same colour as your marking object.
  4. How to Fix a Leaning Wooden Gate: 4 단계, 이미지 3개 중 1개 How to Fix a Leaning Wooden Gate: 4 단계, 이미지 3개 중 2개 How to Fix a Leaning Wooden Gate: 4 단계, 이미지 3개 중 3개
    • Drill holes on the marked circles.
    • Ensure your holes are the same size as the screw you are using.
  5. How to Fix a Leaning Wooden Gate: 5 단계, 이미지 2개 중 1개 How to Fix a Leaning Wooden Gate: 5 단계, 이미지 2개 중 2개
    • Attach the wheel and place the screws .
    • Depending on what the kit provides, use a wrench to tighten the bolts or a screwdriver to tighten the screws.
    • Ensure that the screw is tightened securely to prevent a loose wheel.
  6. How to Fix a Leaning Wooden Gate: 6 단계, 이미지 2개 중 1개 How to Fix a Leaning Wooden Gate: 6 단계, 이미지 2개 중 2개
    • Remove the object you placed underneath.
결론
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
작성자
1다른 기여자 명과 함께
TenzinY
회원 가입일: 09/08/23
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 465
