소개
Use this guide to fix the wobbly and squeaky arm rests for your “ Living Polyurethane Split Leather” Office Chair (model 068-0935-6).
When you have an office chair for work purposes and it has been over a few years since you got that chair, your arm rest starts becoming wobbly and noisy. It is usually the loose screws and dust particles that make it wobbly and squeaky. Follow this guide to remove the arm rests, clean the screw holes, and reassemble your chair—you won’t have loose arm rests when you’re through!
필요한 것
Use a hex key to undo all of the M3 x 6 mm alloy steel hex bolts.
Turn the hex key in the counter-clockwise direction to unscrew the bolts.
댓글 3개
Suppose that the bolt is not hex or phillips or star, but is completely smooth and the fabric is closed with stitching. After removing the caps that cover the holes in the arm there is just a completely smooth bolt or screw with no way to grip or turn it?????
