주요 콘텐츠로 건너뛰기
How to Fix a Loose Cabinet Knob
필요한 것
  1. How to Fix a Loose Cabinet Knob, How to Fix a Loose Cabinet Knob: 1 단계, 이미지 3개 중 1개 How to Fix a Loose Cabinet Knob, How to Fix a Loose Cabinet Knob: 1 단계, 이미지 3개 중 2개 How to Fix a Loose Cabinet Knob, How to Fix a Loose Cabinet Knob: 1 단계, 이미지 3개 중 3개
    • Remove the drawer from the cabinet/dresser.
    • Do this so you have enough room to work with.
  2. How to Fix a Loose Cabinet Knob: 2 단계, 이미지 3개 중 1개 How to Fix a Loose Cabinet Knob: 2 단계, 이미지 3개 중 2개 How to Fix a Loose Cabinet Knob: 2 단계, 이미지 3개 중 3개
    • Take your screw driver to remove the screw from the knob.
    • Place the screwdriver on the screw turning the screwdriver counter clock wise to untighten the screw from the knob.
    • Knowing that every cabinet and drawers are different will determine how many screws you will need to untighten for this repair.
  3. How to Fix a Loose Cabinet Knob: 3 단계, 이미지 3개 중 1개 How to Fix a Loose Cabinet Knob: 3 단계, 이미지 3개 중 2개 How to Fix a Loose Cabinet Knob: 3 단계, 이미지 3개 중 3개
    • Next, you will then remove the screw from the desired hole.
  4. How to Fix a Loose Cabinet Knob: 4 단계, 이미지 2개 중 1개 How to Fix a Loose Cabinet Knob: 4 단계, 이미지 2개 중 2개
    • Inspect the threading of the screw to see whether the screw is still in good condition or if there is any jagged threading on the body portion of the screw.
    • If your screw does not appear to be in good condition, then you would have to purchase another screw. Remember to take the knob with you to the store so that you can get the correct screw for that knob.
  5. How to Fix a Loose Cabinet Knob: 5 단계, 이미지 3개 중 1개 How to Fix a Loose Cabinet Knob: 5 단계, 이미지 3개 중 2개 How to Fix a Loose Cabinet Knob: 5 단계, 이미지 3개 중 3개
    • Inspect the holes within the knob and drawer.
    • You would perform this step to see if there is any extra debris that was left behind.
  6. How to Fix a Loose Cabinet Knob: 6 단계, 이미지 2개 중 1개 How to Fix a Loose Cabinet Knob: 6 단계, 이미지 2개 중 2개
    • Place washers on the screw.
  7. How to Fix a Loose Cabinet Knob: 7 단계, 이미지 3개 중 1개 How to Fix a Loose Cabinet Knob: 7 단계, 이미지 3개 중 2개 How to Fix a Loose Cabinet Knob: 7 단계, 이미지 3개 중 3개
    • Insert the screw in the desired hole.
  8. How to Fix a Loose Cabinet Knob: 8 단계, 이미지 2개 중 1개 How to Fix a Loose Cabinet Knob: 8 단계, 이미지 2개 중 2개
    • Place the knob in front of the cabinet/drawer where the screw would be in place.
  9. How to Fix a Loose Cabinet Knob: 9 단계, 이미지 3개 중 1개 How to Fix a Loose Cabinet Knob: 9 단계, 이미지 3개 중 2개 How to Fix a Loose Cabinet Knob: 9 단계, 이미지 3개 중 3개
    • Hand tighten the screw on the knob.
    • Since you are holding the screw with your left hand and the knob with your right all you have to do is turn the screw clockwise, so the knob can tighten on the screw.
    • Make sure to hold the knob in place while performing this step.
  10. How to Fix a Loose Cabinet Knob: 10 단계, 이미지 3개 중 1개 How to Fix a Loose Cabinet Knob: 10 단계, 이미지 3개 중 2개 How to Fix a Loose Cabinet Knob: 10 단계, 이미지 3개 중 3개
    • Use your screwdriver to finish tightening the screw in place.
    • Remember to keep the knob in place while completing this step.
  11. How to Fix a Loose Cabinet Knob: 11 단계, 이미지 2개 중 1개 How to Fix a Loose Cabinet Knob: 11 단계, 이미지 2개 중 2개
    • Check to see if the knob is tight and secure.
  12. How to Fix a Loose Cabinet Knob: 12 단계, 이미지 3개 중 1개 How to Fix a Loose Cabinet Knob: 12 단계, 이미지 3개 중 2개 How to Fix a Loose Cabinet Knob: 12 단계, 이미지 3개 중 3개
    • Place the drawer back in the cabinet/dresser.
    • Congratulations! You fixed your loose cabinet knob.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sandra William
회원 가입일: 01/15/19
241 평판
안내서 1개를 작성함
2가이드 댓글
Thanks Sandra. Appreciate all the photos as I really don’t know how to do many home repairs.
W. B. - 답글
Another aspect of iFixit,
Home repair
Kind-hearted, spirited Man -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 43
전체 시간: 4,259
