소개
If your car’s window has become wobbly or refuses to move up and down like normal, it is likely that the window has become detached from the window mechanism. Use this guide to help you reattach the detached car window.
Alternatively, use this YouTube video to fix a detached car window pane. This video shows how to fix a detached car window pane on an MG Rover ZS, but the technique is applicable to many other cars.
필요한 것
동영상 개요
Remove any screws securing the door's inside panel.
Feel underneath the door handles for additional screws, and remove them if any are present.
Feel around the bottom edge of the door's inside panel for additional screws.
If there are any screws fastening the door's handle to the inside panel, remove them.
Remove the door handles.
Use your fingers or a screwdriver to unclip the handle's push rod from the handle assembly.
To reassemble your vehicle, follow steps 1 through 5 in reverse order. Be sure to replace the plastic sheet on the inside of the door using polymer sealant. This sheet is a vapor shield and is designed to prevent vapor from inside the car from getting into the window electronics and mechanisms.
다른 2명이 해당 안내서를 완성하였습니다.
