주요 콘텐츠로 건너뛰기
How to Fix a Loose Connection on a Power Strip
필요한 것
  1. How to Fix a Loose Connection on a Power Strip, How to Fix a Loose Connection on a Power Strip: 1 단계, 이미지 1개 중 1개
    • Before you start, make sure you unplug the power strip from the wall! It is very important, as you will get an electric shock if you do not do so.
    • Take out all the plugs on the power strip.
  2. How to Fix a Loose Connection on a Power Strip: 2 단계, 이미지 2개 중 1개 How to Fix a Loose Connection on a Power Strip: 2 단계, 이미지 2개 중 2개
    • Flip over the power strip.
    • Use a Phillips #0 screwdriver to take out the 6 mm screws on the back of the power strip.
  3. How to Fix a Loose Connection on a Power Strip: 3 단계, 이미지 2개 중 1개 How to Fix a Loose Connection on a Power Strip: 3 단계, 이미지 2개 중 2개
    • Separate the outer shell from the power strip.
    • Most of the outer shells can be separated out very easily after the screws are taken out.
  4. How to Fix a Loose Connection on a Power Strip: 4 단계, 이미지 2개 중 1개 How to Fix a Loose Connection on a Power Strip: 4 단계, 이미지 2개 중 2개
    • Locate two pairs of copper sheets for each socket.
  5. How to Fix a Loose Connection on a Power Strip: 5 단계, 이미지 3개 중 1개 How to Fix a Loose Connection on a Power Strip: 5 단계, 이미지 3개 중 2개 How to Fix a Loose Connection on a Power Strip: 5 단계, 이미지 3개 중 3개
    • Use a screwdriver to push the two copper sheets closer to each other. Do this on all the pairs of copper sheets without a solid connection.
  6. How to Fix a Loose Connection on a Power Strip: 6 단계, 이미지 2개 중 1개 How to Fix a Loose Connection on a Power Strip: 6 단계, 이미지 2개 중 2개
    • Install the outer shell back to the power strip.
    • Put the outer shell on it and press it to install.
  7. How to Fix a Loose Connection on a Power Strip: 7 단계, 이미지 2개 중 1개 How to Fix a Loose Connection on a Power Strip: 7 단계, 이미지 2개 중 2개
    • Flip over the power strip, and then use screwdriver to install all the screws back.
  8. How to Fix a Loose Connection on a Power Strip: 8 단계, 이미지 1개 중 1개
    • Plug the power strip into the wall socket, and then plug electric machine to the power strip to test that if the connection of power strip has improved.
결론
You’re all done!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Xike Cao
회원 가입일: 09/19/21
219 평판
안내서 1개를 작성함
York University, Team F-27, Woodhouse Fall 2021 York University, Team F-27, Woodhouse Fall 2021 회원
YORK-WOODHOUSE-F21SFG27
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 17
지난 30일: 102
전체 시간: 3,055
