주요 콘텐츠로 건너뛰기
How to Fix a Loose Cookware Lid Handle
  1. How to Fix a Loose Cookware Lid Handle, How to Fix a Loose Cookware Lid Handle: 1 단계, 이미지 1개 중 1개
    • Wash the glass of the lid with hot water.
    • Be sure to scrub underneath and around the handle.
  2. How to Fix a Loose Cookware Lid Handle: 2 단계, 이미지 1개 중 1개
    • Clean the glass lid with a dry piece of cloth.
    • Make sure to especially clean below and around the handle.
  3. How to Fix a Loose Cookware Lid Handle: 3 단계, 이미지 2개 중 1개 How to Fix a Loose Cookware Lid Handle: 3 단계, 이미지 2개 중 2개
    • Unscrew the handle from the lid and remove the screw and washer.
  4. How to Fix a Loose Cookware Lid Handle: 4 단계, 이미지 2개 중 1개 How to Fix a Loose Cookware Lid Handle: 4 단계, 이미지 2개 중 2개
    • Clean the hole of the handle with a drop of vinegar and baking soda.
    • Firmly apply the drop of vinegar and baking soda below and underneath the hole, which will clear the surface of any dirt.
  5. How to Fix a Loose Cookware Lid Handle: 5 단계, 이미지 3개 중 1개 How to Fix a Loose Cookware Lid Handle: 5 단계, 이미지 3개 중 2개 How to Fix a Loose Cookware Lid Handle: 5 단계, 이미지 3개 중 3개
    • Clean the screw and washer with a drop of vinegar and baking soda.
    • Allow the parts to dry for about 1-2 minutes.
  6. How to Fix a Loose Cookware Lid Handle: 6 단계, 이미지 2개 중 1개 How to Fix a Loose Cookware Lid Handle: 6 단계, 이미지 2개 중 2개
    • Apply super glue around the hole of the handle.
    • Be cautious when using super glue that you don't spill it over the bigger glass surface.
  7. How to Fix a Loose Cookware Lid Handle: 7 단계, 이미지 3개 중 1개 How to Fix a Loose Cookware Lid Handle: 7 단계, 이미지 3개 중 2개 How to Fix a Loose Cookware Lid Handle: 7 단계, 이미지 3개 중 3개
    • Quickly install the handle back onto the lid using the screw and washer.
    • Be careful not to touch the glue with your fingers.
    • Once again keep it dry for about 4-5 minutes.
    • The loose handle on your glass lid is fixed and ready to use.
결론
작성자
2다른 기여자 명과 함께
Dinuk Warnapura
회원 가입일: 01/11/21
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 47
전체 시간: 2,948
