주요 콘텐츠로 건너뛰기
How to Fix a Loose Gate Latch on a Wooden Gate
필요한 것
  1. How to Fix a Loose Gate Latch on a Wooden Gate, How to Fix a Loose Gate Latch on a Wooden Gate: 1 단계, 이미지 1/2 How to Fix a Loose Gate Latch on a Wooden Gate, How to Fix a Loose Gate Latch on a Wooden Gate: 1 단계, 이미지 2/2
    • Remove all screws and bolts holding your gate latch down.
    • I utilized a Phillips #2 screwdriver and 1/2 in. wrench to complete this task, however your individual gate latch may require other specified sized tools.
  2. How to Fix a Loose Gate Latch on a Wooden Gate: 2 단계, 이미지 1/1
    • Remove the gate latch and verify you cannot shift the gate latch to create new holes.
  3. How to Fix a Loose Gate Latch on a Wooden Gate: 3 단계, 이미지 1/1
    • Sand the entire work area with 80 Grit sandpaper and an electric sander.
  4. How to Fix a Loose Gate Latch on a Wooden Gate: 4 단계, 이미지 1/2 How to Fix a Loose Gate Latch on a Wooden Gate: 4 단계, 이미지 2/2
    • Use an electric drill and and a 3/8 inch carbide drill bit to create the 3/8 in. pilot holes for the anchors that will be installed.
  5. How to Fix a Loose Gate Latch on a Wooden Gate: 5 단계, 이미지 1/3 How to Fix a Loose Gate Latch on a Wooden Gate: 5 단계, 이미지 2/3 How to Fix a Loose Gate Latch on a Wooden Gate: 5 단계, 이미지 3/3
    • Using a hammer, tap in the sleeve anchors with the washer and bolt still attached, to prevent the sleeve and anchor bolt from separating.
    • Keep tapping the sleeve anchor until most of the sleeve is seated in the wood while leaving 12.7 mm of thread protruding from the wood.
    • This will allow you to be able to reinstall the gate latch.
    • Remove the bolts and washers from Sleeve Anchors once they have been inserted into the piloted holes.
  6. How to Fix a Loose Gate Latch on a Wooden Gate: 6 단계, 이미지 1/3 How to Fix a Loose Gate Latch on a Wooden Gate: 6 단계, 이미지 2/3 How to Fix a Loose Gate Latch on a Wooden Gate: 6 단계, 이미지 3/3
    • Reposition the gate handle and the gate latch.
    • Use a a 1/2 inch wrench to fasten the salvaged hardware onto the gate latch.
    • Reattach the gate latch and handle with the new hardware from the sleeve anchors with a 1/2 inch wrench.
결론
Nicholas Stockdale
회원 가입일: 05/27/23
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 34
30일 전: 142
전체 시간: 1,263
