주요 콘텐츠로 건너뛰기
How to Fix a Loose Louver in Wooden Sliding Shutters
필요한 것
  1. How to Fix a Loose Louver in Wooden Sliding Shutters, How to Fix a Loose Louver in Wooden Sliding Shutters: 1 단계, 이미지 1/1
    • Clean the louvers with the disinfectant wipes.
  2. How to Fix a Loose Louver in Wooden Sliding Shutters: 2 단계, 이미지 1/1
    • Locate the broken or loose louver.
  3. How to Fix a Loose Louver in Wooden Sliding Shutters: 3 단계, 이미지 1/2 How to Fix a Loose Louver in Wooden Sliding Shutters: 3 단계, 이미지 2/2
    • Align the louvers so they are parallel to the ground.
    • Make sure the knob is facing the tilt bar NOT away from it.
  4. How to Fix a Loose Louver in Wooden Sliding Shutters: 4 단계, 이미지 1/1
    • Tilt the louver down creating a 30 degree angle with the bar.
  5. How to Fix a Loose Louver in Wooden Sliding Shutters: 5 단계, 이미지 1/1
    • Position the knob in between the two holes.
  6. How to Fix a Loose Louver in Wooden Sliding Shutters: 6 단계, 이미지 1/1
    • Insert the pin into the two holes.
  7. How to Fix a Loose Louver in Wooden Sliding Shutters: 7 단계, 이미지 1/2 How to Fix a Loose Louver in Wooden Sliding Shutters: 7 단계, 이미지 2/2
    • Push and secure the pin.
  8. How to Fix a Loose Louver in Wooden Sliding Shutters: 8 단계, 이미지 1/2 How to Fix a Loose Louver in Wooden Sliding Shutters: 8 단계, 이미지 2/2
    • You are finished!
결승점
Fatima Sakhri
회원 가입일: 05/08/20
157 평판
안내서 1개 작성함
York University, Team S1-G23, O'Regan Summer 2020 York University, Team S1-G23, O'Regan Summer 2020 회원
YORK-O'REGAN-SU20S1G23
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 1,110
