주요 콘텐츠로 건너뛰기
How to Fix a Loose Oven Handle
필요한 것
  1. How to Fix a Loose Oven Handle, How to Fix a Loose Oven Handle: 1 단계, 이미지 2개 중 1개 How to Fix a Loose Oven Handle, How to Fix a Loose Oven Handle: 1 단계, 이미지 2개 중 2개
    • Open the oven and unlock hinges that are located at the bottom of each side of the oven.
  2. How to Fix a Loose Oven Handle: 2 단계, 이미지 2개 중 1개 How to Fix a Loose Oven Handle: 2 단계, 이미지 2개 중 2개
    • Lift the door up and detach from the oven.
    • Place the door on the floor or any other flat surface.
  3. How to Fix a Loose Oven Handle: 3 단계, 이미지 2개 중 1개 How to Fix a Loose Oven Handle: 3 단계, 이미지 2개 중 2개
    • Unfasten the top 2 screws of the inside of the door ( the ones holding the handle).
    • For this specific oven, a Phillips #0 screwdriver was used. Make sure to check which screw driver fits your oven screws.
  4. How to Fix a Loose Oven Handle: 4 단계, 이미지 1개 중 1개
    • Observe the screws.
    • If rusty, cleanse them. If damaged, replace with new ones.
  5. How to Fix a Loose Oven Handle: 5 단계, 이미지 1개 중 1개
    • Reset and fasten the screws back in tightly.
  6. How to Fix a Loose Oven Handle: 6 단계, 이미지 2개 중 1개 How to Fix a Loose Oven Handle: 6 단계, 이미지 2개 중 2개
    • Place the door back to the oven.
    • Refasten the hinges.
  7. How to Fix a Loose Oven Handle: 7 단계, 이미지 1개 중 1개
    • Test the handle
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Viktoria
회원 가입일: 01/22/19
253 평판
안내서 1개를 작성함
3가이드 댓글
I'm glad to hear that you found the article informative! My goal is to provide accurate and helpful information to anyone who asks. If you have any more questions or topics you'd like to learn about, feel free to ask!
Ava Dave - 답글
δεν κλείνει καλά η πόρτα της κουζίνας. αφήνει κενό επάνω.
Dimitris Georg - 답글
What would I wrap around screw to make a tighter connection; plumber tape, string, super glue?
stevereicher - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 106
지난 30일: 429
전체 시간: 50,136
