주요 콘텐츠로 건너뛰기
How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828
필요한 것
  1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 1 단계, 이미지 1/2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 1 단계, 이미지 2/2
    • Slide the button back to open the battery cover.
  2. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 2 단계, 이미지 1/2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 2 단계, 이미지 2/2
    • Pull back on the tab to release the battery.
    • Pull the battery out, then close the lid.
  3. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 3 단계, 이미지 1/1
    • Remove the screw on the back of the turret with a JIS #00 screwdriver.
  4. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 4 단계, 이미지 1/2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 4 단계, 이미지 2/2
    • Remove two screws from each side of the camera (four in total) using a JIS #00 screwdriver.
  5. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 5 단계, 이미지 1/1
    • Remove the screw on the bottom of the turret using a JIS #00 screwdriver.
  6. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 6 단계, 이미지 1/1
    • Carefully pull the face plate off and lay it down.
    • There is a cable attached to the plate that should not be removed.
  7. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 7 단계, 이미지 1/2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: 7 단계, 이미지 2/2
    • Tighten the two screws using a JIS #00 screwdriver.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Michael Ventura
회원 가입일: 09/08/21
219 평판
안내서 1개 작성함
댓글 한 개
Thanks, I just used this to tighten the pivot on an F828 I got on eBay. Super easy.
photoman12001 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 32
전체 시간: 1,158
