주요 콘텐츠로 건너뛰기
How to Fix a Loose Wooden Door Threshold
필요한 것
  1. How to Fix a Loose Wooden Door Threshold, How to Fix a Loose Wooden Door Threshold: 1 단계, 이미지 3개 중 1개 How to Fix a Loose Wooden Door Threshold, How to Fix a Loose Wooden Door Threshold: 1 단계, 이미지 3개 중 2개 How to Fix a Loose Wooden Door Threshold, How to Fix a Loose Wooden Door Threshold: 1 단계, 이미지 3개 중 3개
    • Use your hands to remove the door threshold.
    • Start lifting it from one of the two ends.
  2. How to Fix a Loose Wooden Door Threshold: 2 단계, 이미지 3개 중 1개 How to Fix a Loose Wooden Door Threshold: 2 단계, 이미지 3개 중 2개 How to Fix a Loose Wooden Door Threshold: 2 단계, 이미지 3개 중 3개
    • Use a paint scraper to remove the old wood glue and dirt that remains under the threshold.
    • Use a cloth to clean the area once you're done scraping off any leftover glue residue.
  3. How to Fix a Loose Wooden Door Threshold: 3 단계, 이미지 2개 중 1개 How to Fix a Loose Wooden Door Threshold: 3 단계, 이미지 2개 중 2개
    • Before applying the glue, make sure you have some decently heavy objects, like books, that you can use for Step 5.
    • Make sure you have enough wood glue to cover the entire mounting surface from end to end.
    • Apply the wood glue on the mounting surface from one endpoint to the other.
    • Immediately go to the next step after applying the glue as it will dry off fast.
  4. How to Fix a Loose Wooden Door Threshold: 4 단계, 이미지 3개 중 1개 How to Fix a Loose Wooden Door Threshold: 4 단계, 이미지 3개 중 2개 How to Fix a Loose Wooden Door Threshold: 4 단계, 이미지 3개 중 3개
    • Place the threshold back in its original position.
    • Press down along the threshold for a few minutes to ensure it is secure.
  5. How to Fix a Loose Wooden Door Threshold: 5 단계, 이미지 2개 중 1개 How to Fix a Loose Wooden Door Threshold: 5 단계, 이미지 2개 중 2개
    • Place heavy books across the length of the threshold to keep the downward pressure while the wood glue dries.
    • Keep the heavy objects on the threshold for at least 6 hours to allow it to dry completely.
  6. How to Fix a Loose Wooden Door Threshold: 6 단계, 이미지 1개 중 1개
    • Using a paper towel or a cloth, clean the excess glue around the threshold.
    • You can lift the books one at a time to check for any excess glue and clean it.
결론
After a few hours, remove the heavy books or other objects covering the threshold and check its stability. If it still feels wobbly, reapply or add glue to the loose area.
작성자
1다른 기여자 명과 함께
Neel Satasia
회원 가입일: 06/07/25
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 31
전체 시간: 162
