주요 콘텐츠로 건너뛰기
How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i
필요한 것
  1. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i, How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 1 단계, 이미지 1/1
    • When you start your engine and one of your tires is low on air pressure, a message will automatically appear on the iDrive display identifying which tire is low.
  2. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 2 단계, 이미지 1/2 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 2 단계, 이미지 2/2
    • Turn on the air compressor by switching the knob from OFF to AUTO.
  3. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 3 단계, 이미지 1/1
    • Firmly attach the tire chuck attachment to the air compressor hose.
  4. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 4 단계, 이미지 1/2 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 4 단계, 이미지 2/2
    • Remove the cap from the tire valve stem.
  5. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 5 단계, 이미지 1/3 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 5 단계, 이미지 2/3 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 5 단계, 이미지 3/3
    • Push the tire chuck onto the valve stem, making sure that it is secure, and you can hear air entering the tire.
  6. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 6 단계, 이미지 1/1
    • Remove the tire chuck from the valve stem.
    • Check the tire pressure using the tire pressure gauge by pressing the gauge onto the valve stem.
    • The tire pressure needs to be 32 psi.
    • If the tire pressure is below 32 psi, continue filling the tire with the air compressor.
    • Once the tire pressure reaches 32 psi, replace the cap back on the valve stem.
  7. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 7 단계, 이미지 1/2 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 7 단계, 이미지 2/2
    • Inside the car, using the control wheel, select Vehicle Info on the iDrive screen.
  8. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 8 단계, 이미지 1/2 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 8 단계, 이미지 2/2
    • Using the control wheel, select Vehicle Status.
    • You will see an image on the display that confirms that all four tires are at the correct pressure.
  9. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 9 단계, 이미지 1/1
    • Using the control wheel, select Perform reset.
  10. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 10 단계, 이미지 1/1
    • Drive the car to a speed of at least 20 mph until a message appears on the display that indicates that the reset is in process.
  11. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 11 단계, 이미지 1/1
    • After 30 seconds of driving, you will see a new message: All Systems OK, confirming that the tire pressure reset has been successfully completed.
결론
Resetting your tire pressure on your BMW X3 is easy to do following these simple steps and photos.
Camryn Stepp
회원 가입일: 02/14/21
193 평판
안내서 1개 작성함
Texas Tech, Team S3-G6, Cowan Spring 2021 Texas Tech, Team S3-G6, Cowan Spring 2021 회원
TTU-COWAN-S21S3G6
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 64
30일 전: 242
전체 시간: 12,776
