주요 콘텐츠로 건너뛰기
How to Fix a Misaligned Desk Drawer
필요한 것
  1. How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: 1 단계, 이미지 1/2 How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: 1 단계, 이미지 2/2
    • Start by pulling the drawer out and detaching it from the hardware mounted to the desk.
    • To do this you need to push the black plastic lever up in order to disengage the drawer's hardware from the desk's hardware.
  2. How to Fix a Misaligned Desk Drawer: 2 단계, 이미지 1/2 How to Fix a Misaligned Desk Drawer: 2 단계, 이미지 2/2
    • In this case the hardware on the left side of the drawer is not functioning properly due to a bent metal piece.
    • Using the flat head screwdriver you can push the metal down around each ball bearing in order to allow the drawer to slide back and forth.
  3. How to Fix a Misaligned Desk Drawer: 3 단계, 이미지 1/2 How to Fix a Misaligned Desk Drawer: 3 단계, 이미지 2/2
    • The hardware attached to the drawer is also not functioning properly due to missing screws.
    • Use replacement screws to properly attach the hardware to the drawer and to allow it to support the drawer's weight.
    • Take a screw from the drawer to your local hardware store for help finding matching screws.
  4. How to Fix a Misaligned Desk Drawer: 4 단계, 이미지 1/1
    • After attaching the hardware slide the drawer's piece into its counterpart on the desk.
    • It can be awkward to maneuver the drawer in alone. You may need to get some help for this step.
  5. How to Fix a Misaligned Desk Drawer: 5 단계, 이미지 1/1
    • Enjoy your fully functioning drawer!
결론
Dante Mazzanti
회원 가입일: 02/23/15
598 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 57
전체 시간: 15,952
