주요 콘텐츠로 건너뛰기
How to Fix a Noisy/Squeaky Bicycle Chain
필요한 것
  1. How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: 1 단계, 이미지 3개 중 1개 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: 1 단계, 이미지 3개 중 2개 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: 1 단계, 이미지 3개 중 3개
    • Place a piece of cardboard under the bicycle to catch excess cleaner.
    • Rotate the foot pedal with your hand slowly, and spray WD-40 bicycle chain cleaner evenly throughout the chain.
    • Only use WD-40 that is specifically made for bicycles. Using normal WD-40 can damage your bicycle chain.
    • The chemical spray is toxic and very unpleasant to smell. Please use a mask or other means of protection on your face and eyes.
  2. How to Fix a Noisy/Squeaky Bicycle Chain: 2 단계, 이미지 3개 중 1개 How to Fix a Noisy/Squeaky Bicycle Chain: 2 단계, 이미지 3개 중 2개 How to Fix a Noisy/Squeaky Bicycle Chain: 2 단계, 이미지 3개 중 3개
    • Use bicycle cleaning tools to clean the bicycle chain, the chainrings, the cogset, and front & rear derailleurs until most of the rust is gone.
    • Some bicycles do not have all of these parts.
  3. How to Fix a Noisy/Squeaky Bicycle Chain: 3 단계, 이미지 2개 중 1개 How to Fix a Noisy/Squeaky Bicycle Chain: 3 단계, 이미지 2개 중 2개
    • Check your chain system, not only on the chain, but also on the chainrings, cogset, and derailleur system. Sometimes this part will also make noises because of rust.
    • Drip the WD-40 bicycle lubricant on one spot of the chain and rotate the foot pedal until the whole chain is lubricated.
    • Repeat this process until the chain no longer squeaks.
결승점
작성자
1다른 기여자 명과 함께
Jiaming Liu
회원 가입일: 09/19/20
97 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 42
전체 시간: 2,803
