주요 콘텐츠로 건너뛰기
How to Fix a Non-Sticky Cutting Mat
필요한 것
  1. How to Fix a Non-Sticky Cutting Mat, How to Fix a Non-Sticky Cutting Mat: 1 단계, 이미지 1/1
    • Place the non-sticky mat on a flat surface.
  2. How to Fix a Non-Sticky Cutting Mat: 2 단계, 이미지 1/1
    • Spray the non-sticky cutting mat with a spray cleaner covering the entire mat.
  3. How to Fix a Non-Sticky Cutting Mat: 3 단계, 이미지 1/1
    • Let it sit for 5-10 minutes.
  4. How to Fix a Non-Sticky Cutting Mat: 4 단계, 이미지 1/1
    • Use a scraper to gently push the dirt off the mat that is causing your cutting mat not to be sticky.
  5. How to Fix a Non-Sticky Cutting Mat: 5 단계, 이미지 1/1
    • Once all the dirt is removed, let it air dry.
  6. How to Fix a Non-Sticky Cutting Mat: 6 단계, 이미지 1/1
    • Once dry, make sure to cover the cutting mat with its plastic cover to avoid the dust sticking to it.
결승점
April Pantaleon
회원 가입일: 09/20/20
349 평판
안내서 2개 작성하였습니다
York University, Team S1-G20, Melo-Thaiss Winter 2021 York University, Team S1-G20, Melo-Thaiss Winter 2021 회원
YORK-MELO-THAISS-W21S1G20
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 6
30일 전: 22
전체 시간: 369
