주요 콘텐츠로 건너뛰기
How to Fix a Papasan Chair Base
필요한 것
  1. How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: 1 단계, 이미지 2개 중 1개 How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: 1 단계, 이미지 2개 중 2개
    • Remove and save rattan from broken sections.
  2. How to Fix a Papasan Chair Base: 2 단계, 이미지 1개 중 1개
    • Remove old nails from the sections that have separated. Pliers may be helpful for nails that are hard to reach with the claw of a hammer.
  3. How to Fix a Papasan Chair Base: 3 단계, 이미지 2개 중 1개 How to Fix a Papasan Chair Base: 3 단계, 이미지 2개 중 2개
    • Glue the split wood pieces together, clamp, and let them dry.
  4. How to Fix a Papasan Chair Base: 4 단계, 이미지 1개 중 1개
    • Nail the thin decorative wood pieces to the larger sections of the frame.
  5. How to Fix a Papasan Chair Base: 5 단계, 이미지 1개 중 1개
    • Screw the circular base and upper to the vertical supports that have become disconnected.
  6. How to Fix a Papasan Chair Base: 6 단계, 이미지 1개 중 1개
    • Screw together two ends of the circular part of the frame. Align the screw to be perpendicular to the seam where the two ends connect.
  7. How to Fix a Papasan Chair Base: 7 단계, 이미지 2개 중 1개 How to Fix a Papasan Chair Base: 7 단계, 이미지 2개 중 2개
    • Nail down one side of the rattan and re-wrap it. Finish by nailing down the other end of the rattan to secure it.
결론
Following these steps will restore your papasan chair to working order.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Cassidy Calcutt
회원 가입일: 03/31/20
289 평판
안내서 1개를 작성함
3가이드 댓글
What screw you used? Screw dimensions?
Lourdes Diaz - 답글
Were u would u recommend get the wicker to wrap chairs , at???
Thanks in advance!!!
Carrmone Bears - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 17
지난 30일: 95
전체 시간: 21,408
