주요 콘텐츠로 건너뛰기
How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520
필요한 것
  1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520, How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 1 단계, 이미지 1/1
    • Press Stop to cancel the print job.
  2. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 2 단계, 이미지 1/2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 2 단계, 이미지 2/2
    • Turn off the printer.
    • Unplug your printer from the power source.
  3. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 3 단계, 이미지 1/2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 3 단계, 이미지 2/2
    • Open the front tray and check for jammed paper.
    • If you don't see any jammed paper, skip to step 5.
  4. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 4 단계, 이미지 1/2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 4 단계, 이미지 2/2
    • Pull the paper out slowly using both of your hands to avoid tearing.
    • If paper tears apart, do not force the paper out. You can remove any remaining paper by accessing the back panel.
    • If you were able to remove all of the jammed paper through the front, there's no need to continue! Simply proceed using your printer as normal.
  5. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 5 단계, 이미지 1/3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 5 단계, 이미지 2/3 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 5 단계, 이미지 3/3
    • Lay the printer on its backside to expose the bottom panel.
    • Remove the two screws holding the transport unit cover in place with a Phillips #1 screwdriver.
  6. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 6 단계, 이미지 1/2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 6 단계, 이미지 2/2
    • Lift off the transport unit cover.
    • Be gentle while removing the cover. You don't want to damage it.
  7. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 7 단계, 이미지 1/2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove any remaining paper gently either using your fingers or a pair of tweezers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ani Gurtsishvili
회원 가입일: 10/20/20
235 평판
안내서 1개 작성함
York University, Team S1-G98, Woodhouse Fall 2020 York University, Team S1-G98, Woodhouse Fall 2020 회원
YORK-WOODHOUSE-F20S1G98
1 회원
안내서 3개 작성하였습니다
댓글 7개
can you show the whole bottom without the tray being in the way? I would really appreciate!
Lex - 답글
it still has the two lights blinking
kresge - 답글
directions did not help, the yellow and ogange till blinks
kresge - 답글
it did not work
kresge - 답글
Papers stuck it won’t budge I’m underneath and it’s gripped it like a vice! Didn’t work where do we go from here this is horrible!
Leah Campbell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 46
30일 전: 234
전체 시간: 11,465
