주요 콘텐츠로 건너뛰기
How to Fix a Rattling Door
필요한 것
  1. How to Fix a Rattling Door, How to Fix a Rattling Door: 1 단계, 이미지 1/3 How to Fix a Rattling Door, How to Fix a Rattling Door: 1 단계, 이미지 2/3 How to Fix a Rattling Door, How to Fix a Rattling Door: 1 단계, 이미지 3/3
    • Remove the strike plate on the door by unscrewing the screws that attach it to the door frame.
    • The type of screwdriver you need depends on the type of screws that hold your strike plate in your door.
  2. How to Fix a Rattling Door: 2 단계, 이미지 1/2 How to Fix a Rattling Door: 2 단계, 이미지 2/2
    • Take the strike plate and put it in your hand. Using the pliers in your other hand, bend the metal tab toward the flat side of the strike plate.
  3. How to Fix a Rattling Door: 3 단계, 이미지 1/2 How to Fix a Rattling Door: 3 단계, 이미지 2/2
    • Place the strike plate back on the door frame and tighten the screws.
결론
Close your door and shake it back and forth to see if it is still loose. Repeat the guide steps as necessary.
다른 2명이 해당 안내서를 완성하였습니다.
Sara Novell
회원 가입일: 04/08/15
209 평판
안내서 1개 작성함
Cal Poly, Team 30-4, Green Spring 2015 Cal Poly, Team 30-4, Green Spring 2015 회원
CPSU-GREEN-S15S30G4
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 96
전체 시간: 39,612
