주요 콘텐츠로 건너뛰기
How to Fix a Razer Naga Trinity Click Button
필요한 것
  1. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: 1 단계, 이미지 3개 중 1개 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: 1 단계, 이미지 3개 중 2개 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: 1 단계, 이미지 3개 중 3개
    • Remove the three pads from the bottom of the mouse.
    • Remove the four screws beneath the pads using a JIS #1 screwdriver.
  2. How to Fix a Razer Naga Trinity Click Button: 2 단계, 이미지 2개 중 1개 How to Fix a Razer Naga Trinity Click Button: 2 단계, 이미지 2개 중 2개
    • Press the top of mouse and pull back to disconnect the mouse shell.
    • Pull out the cord that connects the RGB button.
  3. How to Fix a Razer Naga Trinity Click Button: 3 단계, 이미지 2개 중 1개 How to Fix a Razer Naga Trinity Click Button: 3 단계, 이미지 2개 중 2개
    • Remove the right shell.
    • Disconnect the cable connecting the left shell to the mouse.
    • Remove the left shell.
  4. How to Fix a Razer Naga Trinity Click Button: 4 단계, 이미지 1개 중 1개
    • Use a safety pin to unlatch the clicker buttons.
  5. How to Fix a Razer Naga Trinity Click Button: 5 단계, 이미지 2개 중 1개 How to Fix a Razer Naga Trinity Click Button: 5 단계, 이미지 2개 중 2개
    • Insert the open safety pin to lift one side latch slightly.
    • Do not open the whole part.
    • Repeat for the other side.
  6. How to Fix a Razer Naga Trinity Click Button: 6 단계, 이미지 3개 중 1개 How to Fix a Razer Naga Trinity Click Button: 6 단계, 이미지 3개 중 2개 How to Fix a Razer Naga Trinity Click Button: 6 단계, 이미지 3개 중 3개
    • Remove the clicker and white pin.
    • Gently press the middle part of the copper sheet until it unhooks itself.
    • Pull the bended part of the copper sheet back.
  7. How to Fix a Razer Naga Trinity Click Button: 7 단계, 이미지 1개 중 1개
    • Reassemble the copper sheet with the white pin seated properly.
    • Push the spring down into its place using a spudger.
    • You will hear a click sound if you successfully assemble it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Haoran Ke
회원 가입일: 01/13/22
283 평판
안내서 1개를 작성함
York University, Team S-12, Woodhouse Winter 2022 York University, Team S-12, Woodhouse Winter 2022 회원
YORK-WOODHOUSE-W22SSG12
1 회원
안내서 4개를 작성함
1가이드 댓글
On the latest version of the mouse, the clicker button can no longer be opened...
Jérémie PLAYOUT - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 63
지난 30일: 271
전체 시간: 14,118
