주요 콘텐츠로 건너뛰기
How to Fix a Ripped Necktie Seam
필요한 것
  1. How to Fix a Ripped Necktie Seam, Ripped Seam: 1 단계, 이미지 1개 중 1개
    • Iron the area of the necktie that is ripped.
    • Ironing the necktie allows for clean lines and no wrinkles in the fabric.
    • When ironing, be careful not to burn yourself.
  2. How to Fix a Ripped Necktie Seam: 2 단계, 이미지 1개 중 1개
    • Position your tie with ripped seam facing up.
  3. How to Fix a Ripped Necktie Seam: 3 단계, 이미지 1개 중 1개
    • Gather your thread and scissors.
    • Cut to desired length.
    • Make sure your thread matches the color of your tie.
  4. How to Fix a Ripped Necktie Seam: 4 단계, 이미지 2개 중 1개 How to Fix a Ripped Necktie Seam: 4 단계, 이미지 2개 중 2개
    • Gather your cut thread and needle.
    • Loop your thread through the eye of the needle.
    • Pull the thread until it is even on both ends.
    • Be careful of sharp needle.
  5. How to Fix a Ripped Necktie Seam: 5 단계, 이미지 1개 중 1개
    • Tie the end of the thread with a knot.
  6. How to Fix a Ripped Necktie Seam: 6 단계, 이미지 3개 중 1개 How to Fix a Ripped Necktie Seam: 6 단계, 이미지 3개 중 2개 How to Fix a Ripped Necktie Seam: 6 단계, 이미지 3개 중 3개
    • Poke your needle from the inside of the tie.
    • Pull the thread all the way through until it reaches the tied knot.
    • Leave about 1/4 inches from the original hole.
    • Poke your needle from the outside of the tie and pull thread until knot.
    • Be careful of sharp needle going in and out of fabric
  7. How to Fix a Ripped Necktie Seam: 7 단계, 이미지 3개 중 1개 How to Fix a Ripped Necktie Seam: 7 단계, 이미지 3개 중 2개 How to Fix a Ripped Necktie Seam: 7 단계, 이미지 3개 중 3개
    • Repeat the sewing pattern until you reach the end.
    • Make sure your final thread is through the inside of tie.
  8. How to Fix a Ripped Necktie Seam: 8 단계, 이미지 2개 중 1개 How to Fix a Ripped Necktie Seam: 8 단계, 이미지 2개 중 2개
    • Once the entire seam has been sewn, create a loop with the thread.
    • To tie a knot, bring your needle through the loop and pull.
    • Repeat the knot 2-3 more times.
    • Make sure the knot is flat against the fabric.
  9. How to Fix a Ripped Necktie Seam: 9 단계, 이미지 2개 중 1개 How to Fix a Ripped Necktie Seam: 9 단계, 이미지 2개 중 2개
    • Cut off any excess thread.
    • Do not cut too close to knot or it may unravel.
  10. How to Fix a Ripped Necktie Seam: 10 단계, 이미지 1개 중 1개
    • (Optional) Iron over seam for better results.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Beverly Fan
회원 가입일: 02/02/23
196 평판
안내서 1개를 작성함
UC Davis, Team 2-4, Andersen Winter 2023 UC Davis, Team 2-4, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S2G4
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 84
전체 시간: 2,334
