주요 콘텐츠로 건너뛰기
How to Fix a Ripped Shirt Hem
필요한 것
  1. How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: 1 단계, 이미지 1/3 How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: 1 단계, 이미지 2/3 How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: 1 단계, 이미지 3/3
    • Turn your shirt inside out.
    • Find your shirt's ripped hem.
    • If the shirt has any loose strings, trim them.
  2. How to Fix a Ripped Shirt Hem: 2 단계, 이미지 1/1
    • Iron the area of the shirt where the hem is ripped.
    • If the hem is ripped several inches, you might want to insert sewing pins to keep the fabric in place.
    • It's important to iron because it allows for easier sewing when the shirt stays folded the same way as the non-ripped part of the hem.
    • The iron will be very hot. Be careful as to not burn yourself.
  3. How to Fix a Ripped Shirt Hem: 3 단계, 이미지 1/1
    • Acquire a sewing needle and thread.
    • Take your thread and loop it through the eye of the needle, the hole at the end of the needle.
    • You'll want the thread to be the same color and shade as the original thread. For visual purposes, I will use red in place of black.
    • The needle is sharp.
  4. How to Fix a Ripped Shirt Hem: 4 단계, 이미지 1/1
    • Pull the thread through the needle so that there is an equal length on each side of the needle.
    • Tie the end of the thread together by making a knot.
    • Making an additional knot over the first makes it more secure.
  5. How to Fix a Ripped Shirt Hem: 5 단계, 이미지 1/1
    • Starting on the inside of the shirt, poke the needle through toward the side that is right-side-out.
    • Sew over the original thread for about half an inch to ensure that it's thread won't rip again.
  6. How to Fix a Ripped Shirt Hem: 6 단계, 이미지 1/1
    • Once the needle and thread is pulled through the side that is right-side-out, you will push it back through as close to the original hole as you can.
    • Doing this will make the visible hem as hidden as possible.
  7. How to Fix a Ripped Shirt Hem: 7 단계, 이미지 1/3 How to Fix a Ripped Shirt Hem: 7 단계, 이미지 2/3 How to Fix a Ripped Shirt Hem: 7 단계, 이미지 3/3
    • When you're back on the inside of the hem, make the next stitch a couple millimeters over and diagonal from the first.
  8. How to Fix a Ripped Shirt Hem: 8 단계, 이미지 1/2 How to Fix a Ripped Shirt Hem: 8 단계, 이미지 2/2
    • Continue this pattern so that the inside has diagonal stitches, and the outside has small, staggered dots.
  9. How to Fix a Ripped Shirt Hem: 9 단계, 이미지 1/3 How to Fix a Ripped Shirt Hem: 9 단계, 이미지 2/3 How to Fix a Ripped Shirt Hem: 9 단계, 이미지 3/3
    • Finish sewing the hem. Make sure the last stitch is on the inside of the shirt.
    • Make a knot where you intend for the pattern to stop.
    • It's important to tie the knot as close to the fabric as possible. Doing this secures the stitching.
  10. How to Fix a Ripped Shirt Hem: 10 단계, 이미지 1/1
    • Cut off excess thread.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Kaitlyn Adams
회원 가입일: 09/29/15
247 평판
안내서 1개 작성함
Cal Poly, Team 17-5, Green Fall 2015 Cal Poly, Team 17-5, Green Fall 2015 회원
CPSU-GREEN-F15S17G5
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 57
전체 시간: 11,627
