주요 콘텐츠로 건너뛰기
How to Fix a Ripped Stuffed Animal
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: 1 단계, 이미지 3개 중 1개 How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: 1 단계, 이미지 3개 중 2개 How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: 1 단계, 이미지 3개 중 3개
    • Use Polyester Fiberfill stuffing to fill the stuffed bear via rip. Add more stuffing for a firmer toy.
    • Do not overfill the toy, or it may rip again.
  2. How to Fix a Ripped Stuffed Animal: 2 단계, 이미지 1개 중 1개
    • Insert a thread through the eye of the needle (the hole) and tie it tightly to the needle.
  3. How to Fix a Ripped Stuffed Animal: 3 단계, 이미지 1개 중 1개
    • Make a knot at the loose end of the thread.
    • This is so that the thread doesn't slip through the cloth while sewing up the bear.
  4. How to Fix a Ripped Stuffed Animal: 4 단계, 이미지 3개 중 1개 How to Fix a Ripped Stuffed Animal: 4 단계, 이미지 3개 중 2개 How to Fix a Ripped Stuffed Animal: 4 단계, 이미지 3개 중 3개
    • Push needle through the end of the rip.
    • Continue along the seam, putting the needle through both sides of the rip to create a stitch.
  5. How to Fix a Ripped Stuffed Animal: 5 단계, 이미지 2개 중 1개 How to Fix a Ripped Stuffed Animal: 5 단계, 이미지 2개 중 2개
    • After the rip is sewn shut, tie the end of the thread by creating a knot
    • Create the knot by wrapping the thread around the needle several times Then pull the thread through to secure the knot at the base.
    • Once is enough, but for more security, you can repeat this step twice.
  6. How to Fix a Ripped Stuffed Animal: 6 단계, 이미지 3개 중 1개 How to Fix a Ripped Stuffed Animal: 6 단계, 이미지 3개 중 2개 How to Fix a Ripped Stuffed Animal: 6 단계, 이미지 3개 중 3개
    • Cut any excess thread and you're done!
    • Enjoy your repaired stuffed bear!
결론
작성자
6다른 기여자 명과 함께
Megan Nash
회원 가입일: 01/19/16
108 평판
안내서 1개를 작성함
Oakland University, Team 6-1, Walwema Winter 2016 Oakland University, Team 6-1, Walwema Winter 2016 회원
OAK-WALWEMA-W16S6G1
10 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 293
