주요 콘텐츠로 건너뛰기
How to Fix a Running Loop on a Knitted Garment
필요한 것
  1. How to Fix a Running Loop on a Knitted Garment, Identify the repair area: 1 단계, 이미지 3개 중 1개 How to Fix a Running Loop on a Knitted Garment, Identify the repair area: 1 단계, 이미지 3개 중 2개 How to Fix a Running Loop on a Knitted Garment, Identify the repair area: 1 단계, 이미지 3개 중 3개
    • Locate the running loop.
    • Note: In this repair, the running loop is located at the edge of the sleeve. This is typically a vertical strand of yarn that has pulled away from the surrounding stitches.
  2. How to Fix a Running Loop on a Knitted Garment, Secure the loop: 2 단계, 이미지 3개 중 1개 How to Fix a Running Loop on a Knitted Garment, Secure the loop: 2 단계, 이미지 3개 중 2개 How to Fix a Running Loop on a Knitted Garment, Secure the loop: 2 단계, 이미지 3개 중 3개
    • Insert the mending needle through the base of the loop from the inside of the sleeve. Pull it through gently to secure the loop in place.
  3. How to Fix a Running Loop on a Knitted Garment, Catch the vertical stitches: 3 단계, 이미지 3개 중 1개 How to Fix a Running Loop on a Knitted Garment, Catch the vertical stitches: 3 단계, 이미지 3개 중 2개 How to Fix a Running Loop on a Knitted Garment, Catch the vertical stitches: 3 단계, 이미지 3개 중 3개
    • Carefully weave the mending needle through the vertical stitches and push the loop outwards.
    • Note: This helps to align the loop with the surrounding fabric.
  4. How to Fix a Running Loop on a Knitted Garment, Start hand stitching: 4 단계, 이미지 3개 중 1개 How to Fix a Running Loop on a Knitted Garment, Start hand stitching: 4 단계, 이미지 3개 중 2개 How to Fix a Running Loop on a Knitted Garment, Start hand stitching: 4 단계, 이미지 3개 중 3개
    • Once the loop has been pulled using the mending needle, change the tool for a normal needle and start hand stitching.
    • Note: In this repair we have chosen a colour thread similar to the pattern on the garment, but we encourage you to be creative and choose a completely different colour or add more contrast, just remember to add your personal touch to your repair!
  5. How to Fix a Running Loop on a Knitted Garment, Continue stitching: 5 단계, 이미지 3개 중 1개 How to Fix a Running Loop on a Knitted Garment, Continue stitching: 5 단계, 이미지 3개 중 2개 How to Fix a Running Loop on a Knitted Garment, Continue stitching: 5 단계, 이미지 3개 중 3개
    • Following the steps shown in the pictures, continue to stitch replicating the garment's pattern.
  6. How to Fix a Running Loop on a Knitted Garment, Check the stitch: 6 단계, 이미지 3개 중 1개 How to Fix a Running Loop on a Knitted Garment, Check the stitch: 6 단계, 이미지 3개 중 2개 How to Fix a Running Loop on a Knitted Garment, Check the stitch: 6 단계, 이미지 3개 중 3개
    • In between stitches, check that it is following the right pattern. Test it by gently stretching the sleeve.
  7. How to Fix a Running Loop on a Knitted Garment, Add last stitches: 7 단계, 이미지 3개 중 1개 How to Fix a Running Loop on a Knitted Garment, Add last stitches: 7 단계, 이미지 3개 중 2개 How to Fix a Running Loop on a Knitted Garment, Add last stitches: 7 단계, 이미지 3개 중 3개
    • Following the steps shown in the pictures, add the last stitches to finish the fix.
  8. How to Fix a Running Loop on a Knitted Garment, Clean the area: 8 단계, 이미지 2개 중 1개 How to Fix a Running Loop on a Knitted Garment, Clean the area: 8 단계, 이미지 2개 중 2개
    • Once you have finished with the last stitches, add a knot at the end and gently pull the thread.
    • Use a pair of scissors to clean the area and cut any loose threads.
  9. How to Fix a Running Loop on a Knitted Garment, Finished and ready!: 9 단계, 이미지 2개 중 1개 How to Fix a Running Loop on a Knitted Garment, Finished and ready!: 9 단계, 이미지 2개 중 2개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 84
전체 시간: 616
