주요 콘텐츠로 건너뛰기
How to Fix a Skewed Wheel on a Children's Kick Scooter
필요한 것
  1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: 1 단계, 이미지 1/3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: 1 단계, 이미지 2/3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: 1 단계, 이미지 3/3
    • Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
  2. How to Fix a Skewed Wheel on a Children's Kick Scooter: 2 단계, 이미지 1/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 2 단계, 이미지 2/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 2 단계, 이미지 3/3
    • Remove the two 12 mm button head screws on top using a 4 mm Allen wrench.
  3. How to Fix a Skewed Wheel on a Children's Kick Scooter: 3 단계, 이미지 1/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 3 단계, 이미지 2/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 3 단계, 이미지 3/3
    • Remove the plastic case from the base of the scooter.
  4. How to Fix a Skewed Wheel on a Children's Kick Scooter: 4 단계, 이미지 1/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 4 단계, 이미지 2/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 4 단계, 이미지 3/3
    • Carefully pull the sides of the wheels up and remove them from the spring.
  5. How to Fix a Skewed Wheel on a Children's Kick Scooter: 5 단계, 이미지 1/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 5 단계, 이미지 2/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 5 단계, 이미지 3/3
    • Grab the spring with combination pliers and bend it into a straight position.
    • Don't bend the spring too much as it could snap and replacement would be needed.
  6. How to Fix a Skewed Wheel on a Children's Kick Scooter: 6 단계, 이미지 1/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 6 단계, 이미지 2/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 6 단계, 이미지 3/3
    • Insert the spring into the center section of the wheels.
    • Slide the two rings on the sides of the wheels into the two rods.
  7. How to Fix a Skewed Wheel on a Children's Kick Scooter: 7 단계, 이미지 1/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 7 단계, 이미지 2/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 7 단계, 이미지 3/3
    • Insert the plastic case back into its original position.
  8. How to Fix a Skewed Wheel on a Children's Kick Scooter: 8 단계, 이미지 1/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 8 단계, 이미지 2/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 8 단계, 이미지 3/3
    • Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
  9. How to Fix a Skewed Wheel on a Children's Kick Scooter: 9 단계, 이미지 1/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 9 단계, 이미지 2/3 How to Fix a Skewed Wheel on a Children's Kick Scooter: 9 단계, 이미지 3/3
    • Replace the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
결승점
Amir Issagali
회원 가입일: 01/10/21
169 평판
안내서 1개 작성함
York University, Team S1-G14, O'Regan Winter 2021 York University, Team S1-G14, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S1G14
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 33
전체 시간: 1,449
