주요 콘텐츠로 건너뛰기
How to Fix a Slipping Violin Peg
필요한 것
  1. How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: 1 단계, 이미지 3개 중 1개 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: 1 단계, 이미지 3개 중 2개 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: 1 단계, 이미지 3개 중 3개
    • Completely unwind the string affected by the loose peg.
    • Turn the peg clockwise for strings G and D and counterclockwise for strings A and E.
  2. How to Fix a Slipping Violin Peg: 2 단계, 이미지 1개 중 1개
    • Slide the peg out towards you to remove it from the pegbox.
    • The pegbox contains the holes that the pegs go into.
  3. How to Fix a Slipping Violin Peg: 3 단계, 이미지 2개 중 1개 How to Fix a Slipping Violin Peg: 3 단계, 이미지 2개 중 2개
    • Locate the points on the peg that come into contact with the pegbox.
    • Rub the peg compound all the way around the peg on the points that contact the pegbox.
  4. How to Fix a Slipping Violin Peg: 4 단계, 이미지 3개 중 1개 How to Fix a Slipping Violin Peg: 4 단계, 이미지 3개 중 2개 How to Fix a Slipping Violin Peg: 4 단계, 이미지 3개 중 3개
    • Reinsert the peg by pushing inwards.
    • Turn the peg counterclockwise or clockwise to evenly distribute the compound.
  5. How to Fix a Slipping Violin Peg: 5 단계, 이미지 2개 중 1개 How to Fix a Slipping Violin Peg: 5 단계, 이미지 2개 중 2개
    • Wipe away the excess compound that is outside of the pegbox with a cloth or paper towel.
  6. How to Fix a Slipping Violin Peg: 6 단계, 이미지 3개 중 1개 How to Fix a Slipping Violin Peg: 6 단계, 이미지 3개 중 2개 How to Fix a Slipping Violin Peg: 6 단계, 이미지 3개 중 3개
    • Locate the hole on the peg and insert the string through it.
    • Tightly angle the string away from the peg head with one hand, while turning the peg toward the scroll with the other hand.
    • The scroll is the woodcarving at the top of the violin.
    • After one or two turns, angle the string toward the peg head (vertical alignment).
  7. How to Fix a Slipping Violin Peg: 7 단계, 이미지 2개 중 1개 How to Fix a Slipping Violin Peg: 7 단계, 이미지 2개 중 2개
    • Tune the string.
    • For strings A and E, tightly turn the peg clockwise, and for strings G and D, turn the peg counterclockwise.
결론
To reassemble your device, follow these instructions in reverse order. Be advised that steps 5 and 7 are optional.
작성자
1다른 기여자 명과 함께
Guadalupe Gonzalez
회원 가입일: 08/31/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 50
전체 시간: 411
